Results 1 to 7 of 7
Thread: ignition stuck
    hinrik is offline Hinrik
    VT Commodore 5.0Lt V8
    May 2008
    Default ignition stuck
    just went to start my car and the ignition wont turn. wobbled the steering but that wont do it. have been told that it may be the pin that has dropped out but what ever it is i cant get it out to replace it because it says in my manual that i have to put it into the on postition to get to the pin. what do i do?any way of getting it out??
    holden just told me they cant fix it till monday or tuesday....
    thanks guys
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Your only hope of getting it fixed quickly is a mobile locksmith.
    MY RIDE
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    weve had it happen twice. locksmith will be cheaper than holden but i doubt it will be going until tuesday by the time they get everything. ring local locksmiths and ask who does work for the local holden dealer.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You can get it out if you are handy with tools, but you will need a new barrel and clamp bolt before you start. Take the steering column shroud off and drill the head of the bolt out, then the whole clamp assembly comes off and you can replace the barrel. The bolt is a shear head design the is tamper proof once it is done up. If you do a search on ignition barrel, you will find a few threads on how to change it.
    Visit my Facebook page
    May 2008
    hey guys, i got it out on saturday, just went away over night thinking about it and i then bought a new one and drilled the old one out, i drilled up to the little latched that holds it in and then it came out, wasn't the easiest but a few hrs mukin around and it came out.
    thanks for the help
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    you could of gotten away with jiggling the key around and fishing for the relese pin from the top of the barrel ive had to replace my igniton barrel 3 times, all different causes, but 2 of them were stuck in like buggery... but it took about a hour of jiggling and twisting and gentle tapping for the key to finally turn to ON so i could get to the pin and it popped it out
    VT Berlina S2
    Nov 2008
    SA
    when you get the key to turn, not hard to the whole lock get out for service or replacement.
    remove the top and bottom column covers, and the ignition rubber grommet
    remove the indicator switch and stalk, remove wire connector to metal ring around the ignition lock.
    turn the key to ON
    see a pin on top of the lock barrel and insert a nail or whatever fits
    the lock barrel assy should come out with the key
    If you want/need to inspect the lock barrel and keyways within
    look at the rear end of the lock, see a spring loaded pin that rotates with the barrel. You will also see a notch with a ledge before it. With the key in the lock rotate the barrel until the pin is at the ledge, press the pin in to clear the notch and ratate the barrel so that it can come out. Bang you just lost the pin right!
    DONT take the key out of the barrel or all the keyways will drop out
    check out the keyways for protrusions while rotating in a clockwise direction, it could be that through wear they are preventing the barrel turning. If you figure thats the cause and are really stuck you can file them down a little on the leading side, but it does compromise security as the lock is easier to force.
    The inside of the lock barrel is another source of sticky lock. File away any protrusions at the lands inside so that its smooth.
    Clear any filings or debris before reassembly
    If on reassembly the immobiliser wont allow the engine to start (this happened to mine I have no idea why)
    put the key into the ignition lock, turn to ON
    press and hold the door button on the key for 5 seconds, that reinstalls the rolling code
    then turn the key to start the engine
  1. How to remove a stuck ignition barrel VN-VS
    By undar8ed1 in forum Holden Commodore How-To's
    Last Post: 13-02-2012, 04:33 PM
  2. VT Ignition.. Stuck in ACC postion
    By daffyy30 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2008, 09:54 AM
  3. ignition its stuck
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2006, 09:34 AM
  4. Help! Key stuck in ignition!!
    By AZBALL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2006, 08:12 AM
  5. vs statesman ignition stuck on..barrel or BCM ?
    By matt2950 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2005, 08:55 PM
