Results 1 to 4 of 4
Thread: ABS light on dash Brakes seems fine
    VT C/SPORT 5.0L 5Spd
    Aug 2008
    Default ABS light on dash Brakes seems fine
    When I start the car no problems, starts smooth no lights come on in dash, as soon as I start moving the ABS light comes on and stays on.
    Can anyone help me witha starting point.
    All fuses are good, when I take the fuse out for the ABS the ABS light comes on and stays on, however when fuse is replaced the light stays off until I start moving and then on it comes again.
    Fault in Front ABS Hubs????
    Any help would be appreciated
    VT Berlina Wagon S1
    Oct 2008
    I had a similar fault some time back, read this, it could be the common problem experienced with earlier models.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Once you have moved off and the light comes on, what happens if you stop, turn engine off and restart, does the light then stay off? That's what happened to mine and it was a faulty ABS sensor.
    Aug 2008
    azzavt:
    Thx I will chack the front abs lines for damage, and source the retaining clip.
    Where exactly does the retaining clip fit, being a revised item, I would have to fit it?? eg drill anything?
    BlackVXGTS:
    Thx I will check and see. If sensor, which one, Wheel Hub Unit???
  1. Dash warning light (!) I beleive it's brakes?
    By MBS206 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2011, 12:33 PM
  2. brakes on tail light goes out
    By kiwimonaro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2008, 10:00 PM
  3. F***! Red light fine :(
    By benjiaka in forum The Pub
    Last Post: 08-11-2007, 02:06 PM
  4. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  5. Abs Off Light On After New Brakes Fitted
    By Marg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2005, 12:20 PM
