Results 1 to 6 of 6
Thread: coil packs??
    2003 VY
    Sep 2008
    Default coil packs??
    so i have posted a thread about my problem before and i thought i had solved the issue then a few days later it started happening again..
    the problem was when i flooor her or she wants to start to spin the wheels or when i jus rev it in neutral and it gets back to low revs it starts to cough and splutter and die in its back end.. then all of a sudden picks up and takes off...
    you guys suggested plugs n leads so ive done that put all heavy duties in etc. but i was on the "brisbane commodore car club" site and joined up etc etc and just decided to ask there and one of the guys suggested coil packs??
    just checkin if you guys think this could be the problem?
    also estimates of how much to fix??
    cheers in advance fellas
    If All Else Fails, Then You're Probably Driving A Ford
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Could be ****ty injectors.. Old VP was shocking until i replaced them. But i didn everything else first lol. Elimination or mechanic.
    Coil pack is very simple and cheap to replace 2nd hand. New expensive..
    I had a little chug down low, Replaced mine 2nd/hand it picked up a touch better.. There is 2 bolts under the coil pack, And 1 wire. It's that simple to remove.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    2003 VY
    Sep 2008
    okay cheers for the response slick
    take it easy mate
    2003 VY
    Sep 2008
    also coil pack... are they just like the old cars?? cause i cant picture coil pack in a VT for some reason... where are they located? near distributor??
    VX Series 2
    Dec 2008
    Canterbury Area, Sydney
    Coil packs probably the go mate. Batty the coil pack is in place to eliminatate the need for a distributor and coil. Its basically a dizzy and coil in one. the the little square thing, at the front of the motor where the leads come out. Not hard to miss, has numbers 1-6 printed on top of it.
    If its not working, you're not hitting it hard enough.
    VX Series 2
    Dec 2008
    As the other guys said, best bet it to replace all 3 packs. Buy them from Supercheap or Repco etc. Buying Holden direct is a ripoff. Aftermarkets the go bro
  1. Coil Packs
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 05:31 PM
  2. MSD coil packs
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2006, 05:56 PM
  3. coil packs
    By executor in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2006, 11:38 AM
  4. Coil Packs ETC
    By DF_Media in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 11:23 PM
  5. Vy coil packs
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2006, 10:37 PM
