Results 1 to 11 of 11
Thread: Changed bearing and brake pads now trac light and abs are lit up ????
    vx berlina seriesII , vz storm crewman
    Mar 2008
    Default Changed bearing and brake pads now trac light and abs are lit up ????
    Hi all , spent this afternoon replacing my bearing hubs and whilst at it changed my brake pads but now my abs light and trac light are on , connections are plugged in fine hmmmmmm, any ideas anyone vx2 berlina , thanks rich
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Try Resetting your Computer. Disconnect the power from the Battery for around 1 Hour and Reconnect. This will Reset the PCM and BCM.
    See if that Helps.
    Mar 2008
    tried it for about 30 mins earlier but still no luck,maybe i will leave it off all night and try tommorow,thanks
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    When you got the hub did you get a hub that suits ABS. Not a standardas there would not be any sensor ring on the hub to match up with the sensor on the strut just an idea....
    Mar 2008
    i asked burson for abs hub so i hope so,but the sensor plug socket was there on the back,disconnected battery all night will see this morning
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    theres also different hubs if u have ABS and IRS ie..
    lets say hub 'A' is only suited for Right side only with live axle and ABS
    Hub 'B' suited for Left side only with Live axle and ABS
    Hub 'C' is suited for Left side only with IRS and ABS
    Hub 'D' is suited for Right side only with IRS and ABS
    Non ABS cars use the same non ABS hub for either side
    but it is important that you get the correct hub to suit your car as the ABS will not operate correctly otherwise.
    Mar 2008
    no still not happy,left the battery off overnight to reset all memories,but still the orange abs light and trac off are lit up, all i can do is hope burson gave me the correct hub that i asked for or try the old one back on again and see if the lights go off, will prob do that next weekend and see how we go
    Mar 2008
    all sorted ,the plug wasnt pushed in quite far enough, good job i checked before i took it all apart again, ,thanks for the suggestions
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Mar 2008
    148 trade each side from bursons, nice easy job really as long as you plug it in properly
  1. Help Low trac light comes on!!!!!
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2008, 10:46 PM
  2. Some door handles & park brake & brake pads.
    By jabsy1 in forum Parts And Other Items For Sale
    Last Post: 07-08-2008, 09:53 PM
  3. Rear brake pads. Anyone changed them?
    By maginoodle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-10-2007, 07:53 PM
  4. Trac & Power buttons lback light
    By BOGANV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2006, 10:16 PM
  5. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
