hi, can anyone help me? I am trying to remove rear bumper on vx to install towbar and cant seem to undo the first lot of screws... the plastic ones on the top of the bumper... i cant see or feel if there is a nut on bottom or not but if anyone knows this would get me started.. cheeers
I think their plastic screws that hold a clip in.
Are they turning and just not unscrewing?
If so try using a small flat screwdriver between the screw and clip. put some preasure on the screw and see if it unscrews.
As you turn the screw, don't push down, but get a thin flat screw driver and push under the screw head and prise up as you undo the screw.
the screw just keeps turning .... thanks for advice ill give it a go ..
them plastic clips are a pain in the arse.Just use a small flat screwdriver to lifts the screw up & get some needle nose pliers to rip the screw up & out when you can grip it.
