hey,. the other day i wanted to change the light in the boot, so i opened it and took the bulb out, then put it in again, and now no interior lights will work. any ideas how to fix it?
Get a test light and see if it has power if not then i would say a fuse has popped and you popped the light out may of caused a short and blown the fuse..
boganv8 is right if its only the fuse its a 10A fuse mini wedge fuses.
