Results 1 to 13 of 13
Thread: replacing sump on vt v6 commodore
    vt acclaim s2
    Dec 2008
    Default replacing sump on vt v6 commodore
    i cracked the sump on my vt v6 commodore, im looking to replace it, ive been told u can remove the k frame after lifting the motor to remove the sump. is that true? how do u remove the k frame??
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    VP Exec
    Jun 2005
    Yep, but you don't have to remove the 'K' frame completely, just drop it down off the engine mounts.
    vt acclaim s2
    Dec 2008
    all good, done it yesterday, all ya have to do is undo the engine mounts and lift the motor about 50mm (2 inches) and the sump comes out quite easily, me and a mate did it in about 4 hours...
    VY ute
    Jun 2009
    did you have to disconnect the a/c, fuel lines etc that are hard piped? im about to replace mine on a VY so any info or tips you have would be much appreciated
    thanks in advance
    98 VT 3.8 auto
    Oct 2009
    does anything have to be removed from the top or rear of the engine to lift it the 50mm
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    I dont think so, those pipes have some flex on it. When i had my mounts changed, they lowered the car down on a hoist with a seperate stand under the sump and dropped it down onto it to lift it.
    VY Calais Supercharged V6
    Jun 2005
    Just thought i'd reply to this thread if anyone ever gets stuck doing this job with a bit more info.
    This is how i did it yesterday at home. I doubt most ppl doing this have a compressor and air ratchet but it makes life so much easier when removing. Obviously delicate sump bolts need to be done by hand when refitting tho.
    Jack up the front of the car, and place jack stands on the chassis rails.
    Removing front wheels gives you more wiggle room but not necessary.
    Undo the engine mount nuts, 2 on each side, 15mm nuts.
    Remove 2 bell housing bolts that go into the sump from the back, 19mm bolts
    With a piece of timber jack up the transmission from the bell housing area until it is at its maximum height, you will see it start to lift the car slightly off your jack stands. it is ok if the engine mount studs come out of their housings
    undo all the 10mm sump bolts, you will need a 1/4 inch drive with a uni. and a 10mm ratchet spanner for the front ones.
    The sump should fall free now but you wont be able to remove it yet.
    Undo the two 17mm nuts and bolts holding the steering rack in place and lever it out until it is sitting free, dont worry the tie rods, intermediate shaft and lines will hold it in place.
    I removed the oil pick up, two 8mm bolts.
    Then the sump was free.
    Use a genuine gasket, these are metal, aftermarket ones are cork and wont last 10 minutes.
    Use plenty of sealant after you've cleaned it all up.
    Put the sump and oil pick up back in with thread lock or locktite.
    Refit all the nuts and bolts and rack too.
    Now, you will notice there is no way in hell those engine mounts are going back in.
    Get a ratchet strap around the upper parts of them and ratchet it with a rag against the sump.
    ie - the ratchet strap goes around the engine mounts and the hooks hook into each other. Then you can tighten the ratchet mechanism and slightly lower the engine/trans. once one stud is close, use a lever bar to lever the other stud in against the one that is just aligned. its hard to explain but you'll see what i mean when you do it.
    do the same on the other side.
    wait 2 hours for the sealant to dry, add your oil and check for leaks.
    Wash off the old oil stains with degreaser the next day.
    cheerio
    Vt commodore
    Jan 2012
    Moranbah
    Just wondering if you bought the new sump off the Internet. If so what website did you get it off?
    vz wagon
    Aug 2006
    Wild west of Melb
    or you can unbolt 1 mount from the engine and drop the motor down and then put the other side back on.
    holden vx executive s2 vx v6
    Feb 2010
    i just got told by the mechanic today that my sump gasket is leaking on my 3.8 ecotec, and to leave it as its a tough job, ie, taking out the k frame ect, now that i have read the above i think the mechanic is talking sh#t, so im going to grab a mate and give it a crack, but has anyone who has done this taken any pictures of the process by any chance?
    Feb 2010
    Jun 2005
    Quote Originally Posted by Rano11 View Post
    also do you have to undo the upper control arms from the k frame?
    Read what i wrote up there it lists what you take off. But no, dont remove subframe or control arms
  1. sump in a VT Commodore acclaim
    By holdenrcool in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-10-2007, 05:07 PM
  2. Replacing door speakers in commodore VR?
    By kyle_vovin in forum Car Audio
    Last Post: 05-03-2006, 11:03 PM
  3. Replacing the Sump Gaskets
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-03-2006, 02:49 PM
  4. VT Commodore - Replacing Brake Pads
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2005, 02:54 PM
  5. Replacing a sump gasket
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2004, 07:07 PM
