Results 1 to 6 of 6
Thread: FOG light switch
    vx sr2
    Dec 2008
    Arrow FOG light switch
    HI i got aftermarket foglights, i have the original holden fogswitch and i don't know how to connect it into the right pins, i've installed heaps of foglights but i got no idea how to connect the gmh switch to the fog lights
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Easiest way is to use the plug that for the fog light switch.It's behind the light switch and you can use the existing wiring for the fog light. The wiring should already be in place.
    MY RIDE
    vx sr2
    Dec 2008
    i had a look just now and the only thing behind it is one small wire with a plug nothing else?
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Its a white square plug,taped to a loom tucked behinde the drivers door side air went.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by VX-ACLAIMII View Post
    As VT Acclm said, it will be taped to a loom and might require a bit of searching. You will probably find 2 plugs, one is for the foglight switch, the other is for the headlights on all the time option. The wiring for the actual lights should be behind the front bumper, sort of either side of the radiator support. Plug in a relay and fuse and you are good to go.
    MY RIDE
    vx sr2
    Dec 2008
    thanks guys hooked the plugs + lights cheers lol found them
  1. Light Switch
    By Holden V8 SS Ute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2008, 02:42 PM
  2. WTB VT VX fog light switch
    By wwilde in forum Swap / Wanted to Buy / Trade
    Last Post: 26-01-2008, 12:02 AM
  3. VS Fog Light Switch
    By revin rosco in forum Electrical Wiring / Questions
    Last Post: 31-07-2006, 08:07 PM
  4. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
  5. Light Switch
    By Dan_8933 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2006, 09:22 PM
