has anyone experienced this before. the threded rod that you put a nut on to hold ur wheel is loose n it can be pushed in. how does this happen and how can it be fixed?
It is called a wheel stud and can easily be replaced. They are pressed in and you can try tightening the nut to fix it but if it won't go back in properly just get a new one for a few bucks.
MY RIDE
its connected to the disks yer? strange never new that could happen. thanks. so its an easy fix as i only has four bolts holding my front wheel on
take the wheel off. look to see if the stud comes fully into the hole. is so put some locktight on it and do it up. might hold it or its a new stud. think you have to undo the brake caliper. by the sound of your description find somebody to do it for you.lol
