Results 1 to 11 of 11
Thread: VT Headgaskets
    96 VS II Acclaim
    Dec 2007
    Default VT Headgaskets
    Hi Guys,
    I'm looking at buying a VT Commodore and would like to know on average these v6 motors pop headgaskets?
    I'm sick of replacing headgaskets on Fords.
    I haven't owned a Commodore for some years, my last on was a VB, why I went Ford I dunno.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    nowhere near as often as the fords. and you dont need to replace the bolts when they do go.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    The only time ive heard of people doing a head gasket on an ecotech was from either from it over heating and them continueing to drive, or from people running stupid amounts of boost.
    We have done 260,000's and havent had a single problem with the motor, just serviced every 10,000. Great reliable engine.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    96 VS II Acclaim
    Dec 2007
    Thanks for the feedback.
    So I should be safe buying a VT with around 150,000klms on it without having to change a headgasket in the next few months. ?
    Mar 2008
    i was only talking to a mechanic about this the other day, they said they can only remember replacing the head gaskets on 1 and that was cause it had been drive for a while over heating,
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by WhiteOx View Post
    assuming it hasnt had the shizen flogged out of it, or the gasket isnt almost gone, you should be fine.
    96 VS II Acclaim
    Dec 2007
    Thanks guys, I guess I'm just paranoid after having to do headgaskets on both the fords at around 150000k
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Yea there is something about fords and head gaskets. I had a Ford Laser for 1 day.... BANG the head went. Got a new head put on... 2 days later BANG the head went again. Just ended up throwing the car away, POS ford. The alloy head straight six's are aweful with head gaskets, ive heard stories of people only just getting into the red of the temp gauge and the head went.
    In the VT's im sure Head Gasket technology had improved heaps over the course of the V6. Are the ecotec's alloy or cast iron heads?
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by Paiste402 View Post
    none of the commodore v6s ever really had a problem with head gaskets. the ecotec heads are still cast iron same as pre ecotec.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    the only thing that goes on them that looks like its the head gasket problem is the inlet manifold gaskets but thast a really easy fix....other then that i only here of them going if (as said) u have massive ammouts of boost and flog the crap outta it causeing it to overheat.
    even so me VN V6 overheated...well it was at red for a bit lol and it never caused me any problems and it had 350 000 on teh clock.......still running aswell as now me mate has it:P
    fords are ****house when it comes to head gaskets.....why they never fixed teh problem i will never know
    96 VS II Acclaim
    Dec 2007
    Thanks for the info
    I was undecided as to buy an AU Fairmont or a VT Commodore but as someone said the VT has cast iron heads I think I'll be leaning towards the VT.
    Quote Originally Posted by jas98 View Post
    I know what you mean .... I owned a 5.0L HQ Statesman a few years back and done the inlet manifold, the sump had about a bucketful of water mixed in with the oil.
  1. 5l cometic headgaskets
    By eaton v8 in forum V8 Development and Modification
    Last Post: 12-09-2008, 09:53 AM
  2. re-torquing headgaskets?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2007, 04:54 PM
