hi guys, i need to know what sort of nut(like what width it is) is the one on the drive pulley on the alternator. i got a v6 vx by the way. nut just came of the car while driving so did the drive beltgot a pic of nut attached.
thanks
This should answer ur question..Good luck..
yup mate that the nut, any idea where i can get one? thanks for that info
thanks alot for the help mate, hopefully they will be no int. damage
a spring washer and a nut u can get anywhere from, or if u wanted to make sure it doesnt come off again use a flat washer and a nylock nut . same alt should be alright to use unless the thread is damaged
