gday
i just bought a VT and it has no badges so i can't tell if its a executive or berlina or anythin. the badge says -
General Motor Holden Automatic Limited
Model - VT8VK69-114 Built - Sep97
Body No - L267543 ENG - LN3
Trim - 171 Trans - M30
Paint - J073 A/C - C60
Susp - STD Axle - GU4
Can someone help me out?
cheers
check out redbook.com.au
and fill out what you know about the car (eg. v6, sedan etc.), and you may filter the results down to a couple of cars
hope that helps you out a bit
Go find the build sheet under the carpet, does it say on the rego if its got rego.
can tell by using the vin numbering system, attached is the vin number for vt series 1. i thinks its based on the executive series
if its got no options, is obviously an exec. if its got traction control button its an acclaim, if its got power windows its a berlina, if its got fog lights its a calais. bit vague, but hope it helps. and yeah, vin number tells all.
Judging by Kurhas's post, its a 1997 VT Executive sedan.
Originally Posted by som
Exactly, the K in the model code (and the VIN, I'd imagine) points to the car being an Exec, all you need to know![]()
