Results 1 to 6 of 6
Thread: Fuel pressure regulator
    chromic's Avatar
    chromic is offline Donating Member
    VT V6 Sedan, VY SS sedan
    Nov 2005
    Default Fuel pressure regulator
    My vt v6 is slow to start. Assuming it was the fuel pressure regulator, I decided to take a look and noticed it is attached to the fuel rail (Unlike the vr v6 which is held by a allen key and sealed with an o ring).
    Surely I don't have to get a new fuel rail as well? How do I get the fuel pressure regulator off?
    I suppose I could get the starter motor tested as it could be a bit lazy.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    There is a snap ring that holds the regulator in place.
    MY RIDE
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    By the holden workshop manual, you have to take off the fuel rail to remove the fuel pressure regulator. I have not figured out why yet, but i will be doing the job soon for the same reason as yourself. When disconnecting these components, make sure that you are weary of contaminants that may go into your fuel system. When you remove the fuel pressure regulator, have a rag ready for the excess fuel to spill out.
    chromic's Avatar
    Nov 2005
    Quote Originally Posted by accentstencil View Post
    Excellent, thanks!
    Quote Originally Posted by jazza15 View Post
    Thanks for that, I will see if I can get away with not having to take off the fuel rail in the next few days when I have a go at replacing it. Good luck with yours too
    VX commodore wagon
    Mar 2011
    collaroy , sydney
    hi , did you have to take the fuel rail off to replace the regulater ? or did you leave the rail in situ , regards Paul
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    I just had mine changed for around $280 !!! It was leaking passed the regulator when it was meant to cut off fuel into the lines as i have dual fuel. Mechanic said that Holden take off the top end with fuel rail, but i watched him and they somehow got to it from behind it. Decent job though. They removed all the EGR valve and gear etc.
  1. Where to get a fuel pressure regulator?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2008, 08:49 AM
  2. fuel pressure regulator
    By harro_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2007, 10:13 PM
  3. fuel pressure regulator
    By mason_luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2007, 10:28 AM
  4. Fuel Pressure Regulator
    By vl 88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-01-2007, 11:46 PM
  5. fuel pressure regulator
    By tynuts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2006, 11:12 PM
