One of the headlights on my VX Acclaim has a cloudy appearance
So far, I've been unable to remove it, any thoughts/ideas?
Thanks
Paul
It appears to be on the outside although I'm not totally sure
Ive heard of a few ways to remove this:
1. Cutting Compound like Scratch X, just use it like you would on paint (I've Done it this way and it work quite well)
2. A very fine grit sandpaper (Maybe 2000 grit? i don't know)
-Smit
Try and polish it off. My headlights are sort of stuffed (from the car bra i think)... sort of has a cloudy appearance and i think the bra has removed a thin film from the headlights... polish has helped it but not totally fixed it.
sun sand and stones buggers the plastic up
gone are the good old days of glass headlights![]()
I polished mine every week for a year. It starts to get expensive, just replace it
super cheap have a product called headlight restorer it comes in a kit, not sure how much it is but i seen it there yesterday.
cheers
Ben
I bought the headlight restorer from Supercheap ($28)
It comes with 4 grades of wet and dry (1000, 1500, 2000 and 2500 grit)
Fortunately my headlight didn't have any scratches, so I was able to start with the 2000 grit followed by 2500 and a few applications of the liquid polish
Very happy with the result and will be interested to see how long it lasts
Thanks for your advice, especially Ben
Regards
Paul
Vuplex or Meguiars PlastX which i used to fix my dash gauge cover that was hazed from dash protectants.
i get moisture in my driver side light that gives it the cloudy look
bl**dy annoying
im gona pull the faces off of them n polish the inside n seal with silastic
i would get a headlight restoration kit from autobarn because you headlights are crazing... adelaide pauls way is most of the time effective depending on how bad your lights are
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
well i have used regular car polish on my lights and now they just shine!
they didnt have a cloudy appearance, just pretty scratched up.
have you changed yours globes recently? you mustn't ever make contact with the globes with your skin. - this gets acids on the globe. when the globe is refitted and turned on, the acids evapourate into the light cluster and gives a nice cloudy effect![]()
