Results 1 to 10 of 10
Thread: Drivers side headlight not working
    VX Calais SeriesII
    Feb 2007
    Exclamation Drivers side headlight not working
    Hi all,
    My drivers side headlight stopped working the other day. Have checked and tested the globes, fuses and relays and all are OK. The passenger side headlight and all others lights are all working fine. I was wondering if disconnecting my battery for an hour to reset the BCM would work?? Any advice is greatly appreciated.
    Thankyou
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Try puting the one from the passenger side in just to make sure that the other one is at fault . Is the easiest and cheapest way to go first up .
    VX Calais SeriesII
    Feb 2007
    Thanks Dayvo,
    Same result, high beam and everything else is fine. Just no drivers side headlight.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Quote Originally Posted by calaiswa View Post
    Thanks Dayvo,
    have you checked the wire connectors lol..... if they are in properly then i would trace the wires back to the relay if that doesn't work then call in an auto elec because if it was your BCM it would be that both lights don't work.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Have a look inside the plastic conector that plugs into the light and check to make sure that all three wires are in place and havn't come unclipped
    VX Berlina 3.8
    Jun 2009
    I know this is an old post but I have the exact same problem and before I take it to an auto elec I was wondering if the problem was resolved?
    VT
    Dec 2008
    I think there is a fuse in the engine bay where the relays are located that has something to do with this. Check to see if one of them is blown. from memory it is a 20 amp fuse.
    VX Berlina 3.8
    Jun 2009
    Thanks gc5571, the fuses are fine so I have to trace wires, check relays etc, the seach continues.
    Does anyone have a diagram of what fuses and relays are in the engine bay fuse box - my stick on guide under the lid is missing so I have no idea what is what, thanks.
    VT II Berlina
    Feb 2007
    Macleod (3085), Melbourne
    Quote Originally Posted by JuzAndBec View Post
    Was just looking around for the easiest way to get to the driver's side headlight bulb on a VT, and took pity on you! Here's a pic I just took for you (good luck with finding the problem! I hate electrical gremlins):
    (By the way, I just thought to check whether you have a VT or VX.. my pic is from my VT II Berlina; I imagine your VX will be the same - if anyone who Knows is reading this, hopefully you could confirm!)
    Well, I'm off to remove the battery and install these Philips +50's I just got, replacing the stockies on both sides since I already have to replace the driver's side bulb. Here's hoping they're similar to the Narva +50's which I remember really being impressed with!
    VX Berlina 3.8
    Jun 2009
    Thanks cragv, it's a VX S1. A guy at work has a VT Calais so we checked and all the things are in the same place for the engine fuse box. So we checked fuses, relays and wiring - no joy. Then my friend thumped the egde of the light and bingo!. Go figure, nothing like percussive maintenance.
  1. VZ left side headlight removal
    By Natsirt in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-06-2008, 02:33 AM
  2. Drivers Side Mirror
    By parisian62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2007, 05:24 AM
  3. Changing passenger side headlight
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2006, 05:09 PM
  4. W.T.B. VN passenger side headlight
    By savage1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-05-2005, 05:06 PM
