Results 1 to 15 of 15
Thread: airbox/two hole mod
    Vt S Pack Series 2
    Nov 2008
    Default airbox/two hole mod
    just wondering..if i use a hole saw and cut a hole in the front of my airbox and then stick some pipe from the hole in the airbox to the front bar/ grilles on my vt if that will work instead of doing the hole 2 hole mod thingy?
    it may even be the same haha if any one can give me suggestions..its a stock as a rock vt series 2 s pack. im going to eventually get a a full exhaust and tune up soo what can i do?
    VT Berlina Wagon S1
    Oct 2008
    Check out the "how to" section... it's got a few items under "CAI" that document really well what you're talking about, there's even pictures and such.
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    That basically is the two hole mod; the VT equivelent, as we have no room to fit a PVC pipe :P
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    My CAI mod on my VY SS ute (series 1)
    no you dont use a hole saw
    you mark the hole one the air box then get a drill bit and drill around the mark of the hole then you file it smooth
    cheers GM
    Vt S Pack Series 2
    Nov 2008
    mmm i was wandering that...i was thinking of using that aggie pipe stuff thats fairly bendible but doesnt the engine bay get to hot/pipe over heating?
    2010 Yamaha R1 & 2000 VT SS
    May 2008
    Toowoomba
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by pac3y View Post
    You're right in that it's easy to suck hot air. I cut a hole from the front passenger side of the air box on the corner and squeezed some flex pipe right up behind the headlight next to the fender panel. No hot air there.
    VYII Calais L67
    Dec 2006
    Nowra
    at idle you may suck some hot air but soon as you are moving you would be getting cool air from behind the headlight
    cheers GM
    vt s pack
    Jul 2008
    cool cool does any one no the part numbers for a new air box.....i think im gonna buy a brand new one and then cut the hole out of that and then just drop it in..?
    Vt S Pack Series 2
    Nov 2008
    is it really worth buying another box? does any one no how much they are?
    Dec 2006
    Nowra
    Quote Originally Posted by veeteecommo View Post
    just get a second hand lower box from the wreckers
    the MCAI # are
    92102700 Seal
    92102689 Hose
    92096849 Duct
    cheers GM
    Dec 2006
    About $35 new from Holden but I've had one on back order for 7 months. Go to the wreckers
    VYII Calais L67
    VZ Wagon
    Jul 2005
    I just made up the intake pipes for the 2 hole mod and found an easy way to flare the pipe ends. Get a COLD 2litre bottle of coke, flare the hot end of the pipe over it the top of it after heating the pvc pipe on the bbq burners, takes about 3 minutes to flare both pipes, and the cold coke bottle cools the pipe to the right shape! EASY!
    I actually got an empty bottle of **** and filled it with water and put it in the freezer for a firm edge, very easy to do
    sway9 is offline The Rejectz Commodore
    99 VT, Mazda 3 SP23, Hyundai Getz 1.4ltr
    Dec 2008
    Albion Park NSW
    ive done it. i found it just didnt do much my CAI is hundreds of times better. all you get is abit of noise and a little extra throttle response nothin major
  15. #15
    VZ Wagon
    Jul 2005
    has anyone adapted a CAI to fit the vz? I have heard alot of for/against argument on the 2 hole mod and think if you could isolate the airbox a bit better so air only comes from the front it would be better.
    I have dont the mod and notice the "growl" noise more, and slightly better response, but I think after idle and heat soak when at lights etc, the power is not there like when at speed.
    I think if you could isolate the intake more it would definitly be better.
    No way am I paying 300 for this setup
    COLD AIR INTAKE KIT VZ ALL 6 CYL"FACTORY LOOK" NEW - eBay Air Filters, Induction Kits, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 18-Jan-09 21:44:05 AEDST)
    But there must be a cheaper way to acheive the same result
  1. 2nd hole in the air box
    By vzlumina in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-11-2008, 05:39 PM
  2. 2 Hole Mod Help!!!
    By wingwang99 in forum General
    Last Post: 23-10-2008, 01:04 PM
  3. 2 hole air box mod
    By Nanos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2008, 09:40 PM
  4. key hole????
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2008, 03:55 PM
