Results 1 to 2 of 2
Thread: Oil burning under neath my bonnet
    VE Calais
    Sep 2008
    Cheltenham, Victoria
    Default Oil burning under neath my bonnet
    Changed my heater tap today, no more leaking which is awesome... something i never took notice for that I did notice today was that on the left side of my engine i can see smoke and oil burning close to where the spark plugs are mostly at the back side of the engine.. if i sit there revving the car around 4,500+ rpm for over 20 seconds or so.. it seems more oil appears to be burning towards the middle and very noticeable.. this has been like this for awhile i think as I have always smelt oil burning when i use my heater and just never took notice of it until today. Should I be concerned? cars @ 220,000km car was pushed a little bit during its 180,000-210,000km of its life before that it was looked after and now it has been too just the odd, once in awhile foot to the floor sorta thing.
    Any ideas.. always good. Thanks
    GrEnAdE is offline Nade
    VX S
    Dec 2008
    Blenheim NZ
    have a look at your rocker cover seals......clean around the point where the rocker cover joins the head and keep an eye on it for a few days.....if its leaking round there you should see obvious signs of oil seeping out. Then its a simple fix....new seal and a clean up. Check the other side too....often they leak into the valley and you may not see it until it runs over the back and down around bellhousing.....messy to say the least. Mines done 179 000kms and has just showen up the leak in a similar place.....I only noticed it when taking it in for a WOF and it was pointed out.....what a mess!!!
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. Burning Oil ???
    By fullaaa in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 03:13 PM
  3. burning oil
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-08-2006, 09:22 AM
  4. burning dvd
    By xu1au in forum The Pub
    Last Post: 01-08-2006, 05:39 PM
  5. Need help with burning DVD...
    By Hairy Eater in forum The Pub
    Last Post: 27-04-2006, 07:14 PM
