Looking to get a little more power out of my stock VT, nothing extreme but just some nice mods for a little more.
I want to keep the car looking and sounding as stock as possible to avoid additional unwanted attention.
So far people have suggested performance chip which I am looking into (with greenfoam) and also a slightly lumpier cam (crow cams 8531561 so minimal extra work is needed to accomidate. I am not to sure on the cam and how worthwhile it is so help there is appreciated
I can live with a little extra noise as long as it isn't boomy or excessive, the quieter the better.
cold air intake - $0 to $300 depending on what u get
panel filter - $100 or pod filter setup about the same
1.9 roller rockers - $700ish
81* thermostat - $20 if ur give it alot of stick
oh and stickers +50kw![]()
just get a raptor sc would be way better than a cam
Supercharger is a tad out of price range.
Which CA intakes are reccomended for VT?
the factory holden supercharged one is pretty good and just bolts in
also u can get from local holden dealer or wreaker but just get the ratio rockers they worth every penny ( pitty they cost so much more in nz ) and if u can by law just remove the back muffler and put in a st pipe it dosn't make it much louder and keeps in the cats as u need them in aussyha ha
Changing the diff gears is probably the most "slient" mod you could ever do..
-Nick.
ours has a shaved head, bigger stainless valves , flow tested, bigger exhaust but same size mufflers to keep it down. chip redone and is getting a cold air intake when i get some money
