Results 1 to 10 of 10
Thread: Made sparks, stuff stopped working
    1999 VT Commodore Acclaim
    Nov 2008
    Default Made sparks, stuff stopped working
    I was drilling in the engine bay to mount a fuse and the chuck of the drill rubbed its way through the positive wire for what I believe is the emmision control (Box with steel pipes running from it mounted behind cruise control box). Since the chuck hit positive and the bit was contacting the body, sparks flew.
    The car starts however my ABS and traction now dont work, any ideas?
    cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by usernameguy View Post
    cheers
    That was the ABS module you drilled into, not good.
    MY RIDE
    Nov 2008
    You mean the ABS module I shorted??? I drilled into the body, the chuck wore away the wire insulation and shorted.
    Nov 2008
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    Nov 2008
    Nov 2008
    I was watching where I was drilling not where the chuck was, The bit didn't hit the wire the chuck did.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Have you repaired the wire(s) and checked the fuse?
    MY RIDE
    Nov 2008
    Checked the fuse, not blown and the wire was not broken just insulation worn away, electrical tape over the wire and then taped the wire bunch back together.
    No strands appeared to be broken on the wire since I pulled the drill away as soon as it contacted and sparked. I will change the fuse over tomorrow just in case im missing a small crack.
  1. My key stopped working.. :(
    By Howks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2008, 11:52 PM
  2. Speedo stopped working!
    By jay_hman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2007, 11:46 PM
  3. blinkers stopped working
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 11:56 AM
  4. Dashlights Stopped working
    By Res0n8 in forum Car Audio
    Last Post: 16-07-2006, 01:01 PM
  5. Odometer stopped working in VP
    By jabbavx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2006, 05:44 PM
