Results 1 to 6 of 6
Thread: VT After 30mins Engine vibrates and littel power
    VT S Pak Commodore
    Dec 2008
    Default VT After 30mins Engine vibrates and littel power
    Hi
    I have a strange problem on my VT S Pak, After 30 mins driving from a cold engine start, the enigne will suddenly vibrate heavily when accelerating, with total lack of power. Then need to rest the car for 20 mins to make the quick 10 min dash home before it happens again.
    The mechanic has already changed the leads and assured me this would fix the issue, but it hasn't. Does anybody have ideas of what this could be or needs checking ?
    Cheers.
    VT spac super6
    Nov 2008
    Riverton sa
    deffinatly sounds electrical..
    get yourself a work manual and check resistance on coils using a multimeter first up
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    That vibration can only be a missfire on one or more cylinders! Check the spark plug high tension leads first of.
    Pablo
    VT Olympic
    Dec 2008
    Check your error codes if you can (see the FAQ)
    Is it misfiring? i.e. does it feel like it is 'surging' under you....
    I would suggest coil packs and ignition module.
    VX V6 Exec. Wagon
    Mar 2007
    well of course nobody has mentioned anything about the plugs. swap them out for a nice new set, wich have been properly gapped and see if there is a change.
    VT S Pak Commodore
    Dec 2008
    Smile
    Hi Folks
    Mechanic was finally able to use scanner showing that the crank angle sensor and ignition module had failed. replaced both of them now everything is running fine on those long trips.
  1. V6 auto vibrates in 3rd gear
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2010, 10:56 AM
  2. Why Mums do give littel boys, dolls!
    By NORTI in forum Jokes/Humour
    Last Post: 14-10-2006, 11:42 PM
  3. new manual in, still vibrates
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 06:42 PM
  4. vr vibrates after holden service
    By danflood in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 12:11 PM
  5. Steering Vibrates/Shakes
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 04:48 AM
