Results 1 to 12 of 12
Thread: PLEASE HELP!!! *URGENT!* - VT Electric window problem!
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Exclamation PLEASE HELP!!! *URGENT!* - VT Electric window problem!
    Have a VT Senator. and my drivers elec window wont go up. Its currently stuck down! And ****ing with rain!
    The switch seems to be ok. tried the other side switch in that door and still does the same thing.
    Its clicking when i try to put the window down. but its all the way down. it does not click or move when we try to put it up.
    Is there a way to put it up? Im currently 2000km from home. so can fix it when i get home!
    cheers
    Jason
    Apr 2006
    VT spac super6
    Nov 2008
    Riverton sa
    Apr 2006
    yeh i have taken it off. (the trim).
    cant see any problems. im wondering if maybe its gone down too far. and has jamed. but the window glass is not tight. so its not jamed glass. it doesnt click when i try and put it up. but when i try to put it down the regulator does click.
    wondering if its a stuffed reg.
    VS l67 statesman
    Dec 2008
    HAD a VP berlina the window woulnd wind down on the drivers side only ,IT turned out the BCM was the promblem ,I replaced it and it worked straigth away ,so if you dont find any stuffed switches try that
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    my wh does the same thing with the drivers window... i just keep clicking it up and down till it works :P longest i had to do that for was like a minute...
    Going where no late model stato/caprice has gone before.... GAME ON!!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by lil_oneblue View Post
    While you have the trim off, connect 12 volts directly to the regulator motor terminals. It doesn't matter which way you connect positive and negative because one way the window should go up and the other way the window should go down. If nothing happens, the motor is cactus.
    MY RIDE
    Apr 2006
    cheers heaps for the replies.
    BSM that sounds scarey.....
    im 99% sure its not the switch as i tried the other side switch on the side that wont go up and does the exact same thing.
    will give the 12V to the terminals a go.
    if i have no luck i will be pulling it out and worring about it when i get home. a block of wood wedged in there should keep it up till then...
    thankyou again for the quick replies.
    Apr 2006
    GOT THE WINDOW UP!!!!!!
    Just jumped it straight off the battery.
    im 99% sure its not the switch but will test the switches when i get home (2000km away)
    Is there anything else that it could be? BCM?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Perhaps the BCM or the wiring in the rubber boot that goes from the door to the body. Sometimes the wires are a bit tight in the boot and from the constant opening and closing of the door, wires can break.
    MY RIDE
    vx ss 5.7 m6
    Dec 2008
    it could be the main window switch in the centre console which can short out internally which would make the rear switch not work
    Apr 2006
    i have a new main window switch comming anyway. so will give it a go....
    cheers
    jason
  1. electric window problem
    By redcedar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2011, 11:13 PM
  2. Electric Window problem
    By SaabPilot in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-07-2008, 10:35 AM
  3. F@#KED Electric Window
    By Tas_HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 06:22 PM
  4. VK Electric window switches
    By hold.on in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-02-2006, 12:29 AM
  5. Electric window problem
    By simmo 76 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2005, 06:09 PM
