Results 1 to 10 of 10
Thread: weird VT calais climate control issue
    VZ
    Oct 2008
    Default weird VT calais climate control issue
    hi guys,
    recently bought the wife a VT calais..nice car and all BUT one thing ive noticed with the climate control is that when youve got the A/C on and you have the setting for the air to come out directed at the face..it will blow onto the front windscreen, and then after sometime then blow onto your face and alternate between the 2..real wierd..and whats even more bizzare is if youre accelerating it will blow onto the front windscreen and then as soon as you get off the accelerator will then blow onto your face..
    all the directions are all over the place..no matter what you select..it will blow onto the front windscreen..
    its kinda ****ing me off..anyone know whats the problem?
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Might just be faulty ? Or it's on Circulation mode ?. Maybe the light is toast on that.
    Mine has started on circulation mode before. Then there is the window button that might be on also.
    But easy fix might be replace the climate control unit they are pretty cheap to buy and pretty easy to replace.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Juztin's Avatar
    Juztin is offline Bigmacs everywhere
    VT II 99', S Pack.
    Sep 2008
    MikesCalais's Avatar
    MikesCalais is offline Trust me, I'm a Doctor
    VE Calais V International
    Dec 2008
    at least its working, mine only works on full speed and nothing less :/ but that would be annoying as hell
    VT V8 Calais
    Mar 2007
    I would check your vacum hoses under the dash behind the glovebox. Do a search on here for this issue. If you have a leak or a hose has come off then you will get these types of problems.
    50LTRv8
    VTII ACLAIM
    Dec 2006
    OK similar problem here... on face mode it will only blow to the feet area, i did notice though that the vacuum type solenoid which has the 2 (i think) vacuum hoses a white and a green (from memory) will not go all the way ie pushed in. If you push the plunger all the way in then the air will blow to the face vent. It seems that the plunger wont suck in all the way. As i said before that there are 2 vacuum hoses a green and a white. the white at the end and the green at the side if the plunger "housing".
    Is there a box that diverts the vacuum these plungers (there are 2 that i can see)
    It would be nice to get the face vent working as it would be the most used one.
    Thanks in advance
    VTII ACLAIM
    Dec 2006
    Quote Originally Posted by 50LTRv8 View Post
    Thanks ill have a look there, i did notice all of the hoses going under the aircon unit but i didnt know there was more behind the glove box
    VTII ACLAIM
    Dec 2006
    OK did have a look and found the following to be the issue.
    Do NOT take the glove box lid and inside lining out..NO NEED
    Simply pull the black cover off BEHIND the glove box, pull it down but it will sort of hinge at the kick panel, again no need to pull the whole thing off.
    You will see a black rectangular box with colored wires (which are actually vacuum hoses), mine seemed ok but i pushed all of them in, they seem to be on a silicon or soft plastic type of manifold setup, still the problem was there but now intermittently.
    Yes are started to come out of the face vent, sometimes, after cycling through vent options.
    I then looked at the electrical connector, i removed the connector checked the wires going into it, all seemed ok, so i thought dirty connector, slid the connector in and out a few times so to clean the pins and now its all good, if i had contact cleaner i would have sprayed some in, but all is OK now
    50LTRv8 thanks for the lead !!!!!
    E3 Maloo
    Dec 2006
    Belconnen, ACT
    i have the same issue, i checked pretty much everything. No luck with getting it to work. More than likely its the ****ty rubber manifold that connects all the vacuum hoses.
    Anyway good to hear you fixed yours, there a few guys around here that have this issue and cant fix it
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I've noticed that in my VZ sometimes, I think it's just a part of how the system works to circulate the air and keep the whole car cool. Not abnormal as far as I can tell because I think the HUD changes the little icon which tells you where it's blowing to the window while it's doing it, so it's knows it's doing it. Will have to read the manual when I'm home!
  1. VP Calais Climate Control
    By jailbar42 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2008, 03:28 PM
  2. VX Berlina Climate control issue
    By Jom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2008, 11:34 PM
  3. VP Calais Weird climate control issues
    By Makkasman01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2006, 10:29 AM
  4. Climate control Fan - Weird noise's
    By calais_cruzin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 11:50 AM
  5. VS Stato Climate Control and Fuel Gauge Issue
    By haloeight in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2005, 07:53 PM
