Results 1 to 5 of 5
Thread: Warning light help (car wasn't sold with a manual)
    HSV +6
    Mar 2006
    Mornington Peninsula
    Default Warning light help (car wasn't sold with a manual)
    Basically the light that came on is under the car temp on a single panel display, it looks like Canberra with a lightning bolt in it under the gauge that tells you the temperature.
    Came on while idling with rear demister on.
    Car seems to be idling strangely too, sits there idling normal then it feels like a massive surge where there's a strong vibration and the engine feels like its struggling.
    Suggestions?
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    How many k's has your car done?
    edit: I know it shouldn't really matter but it'll give us a better understanding.
    HSV +6
    Mar 2006
    HSV +6
    Mar 2006
    Everything else seems to be running fine, its just this thats the issue. And the dash light, of which i still have no idea which one it is, only has come on once today when i was in a drive through.
    Its the engine with the lightning bolt in it, and my car is doing a surge when it idles. So any suggestions on what it could be?
    VX Executive S2
    May 2006
    Frankston South Vic
    engine with lightning bolt is the check engine light (CEL)
    it means there is a problem that needs to be checked, search for checking fault codes
    Checking error codes VT/VX - Just Commodores
    vx fault codes
  1. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  2. Tail light Warning light
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 26-07-2006, 08:15 AM
  3. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  4. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
