Results 1 to 12 of 12
Thread: Custom CAI - VT V6.
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    Default Custom CAI - VT V6.
    Hi Guys,
    Relatively new to the Forum, and let me say it seems a great community.
    Anyway I have a question relating to the intake of my V6 VT commodore.
    There are quite a few different intakes you can choose for the VT commodore, and allot of debate to go with it. Which has got me thinking to make my own, I have seen the “ Two hole mod” for the commodore, but I am thinking to expand on that a little by using a POD filter.
    I am thinking of using the same style intake system as the Race flow, Then using intake pipe out of the side of the cold air box, running down under the radiator(same guidelines as the “two hole mod”.
    So my question is what do some of you guys think of the idea? Because it is a POD style
    System would it defeat the purpose of the second hole intake pipe?
    Any feedback is greatly appreciated,
    Cheers!
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Hey mate,
    unless your going to do some serious engine work then the standard vt v6 cold air intake does the job very well. Perhaps a High Flow filter. But the standard CAI does a great job
    no longer a hoon by association - the commodore is gone
    VT II Phantom
    Oct 2008
    Forest Lake, Brisbane
    I found that simply removing the factory intake & using a K&N filter is all that's needed, unless you want to ram air into the intake (which is useless if you don't run a higher-spec setup).
    And no, temperature is not an issue. Using a pod filter is not really advantageous at all and using one in conjunction with a 2-hole mod would seem a little unnecessary
    Landcruiser TD
    Dec 2008
    Brisbane.
    Quote Originally Posted by jjFarking View Post
    [EDIT] My bad I read it to quick, skipped a word.
    Thanks for feedback so far.
    VXII Berlina Sedan
    Jul 2006
    Adelaide, South Australia
    I have the YT CAI mod - just cut the hole in the side of the airbox and pipe comes out under radiator. I have also put in a K&N air filter in and seems to be working quite well.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    How do you cut the hole out ?..
    I got on order some RR and that CAI from YT. But only thing is i can't figure out how to cut the hole.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VXII Berlina Sedan
    Jul 2006
    Quote Originally Posted by SlickHolden View Post
    Used a 95 or 102mm Hole Drill (can't actually remember which one now!) - you can get them at Hardware shops - allows for the ~100mm pipe and a little extra for the metal bracket which you attach the pipe to it. I think it tells you in the instructions how big you need to cut the hole.
    I had access to a bench press drill and simply marked out the hole, clamped it and drilled out the hole then sanded it to clean it up after.
    I actually went and got a 2nd hand airbox from wreckers when I cut the hole just in case I made a mistake
    Landcruiser TD
    Dec 2008
    Brisbane.
    Looking at that yella terra intake, Has it got any form of filter at the bottom to prevent leaves and other foreign objects going strait into the box?
    Does the yella terra intake give a better sound at all?
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    You can make one from pipe you buy from any plumbers hardware store. You can have mine in a few weeks coz im getting rid of it. They are easy to make im sure theres a write up on here somewhere.
    .:Blown VT V6, DAJ37:.
    2006 VZ SS Thunder 6.0
    Sep 2008
    Mornington Peninsula
    So is the YT CAI the same as the 2 hole mod which gets air from underneath the front spoiler?
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by f1_power View Post
    Thanks for that mate.
    Good idea i'll grab a air box from the wreckers just encase i stuff it up.
    Quote Originally Posted by aone View Post
    Yep. I dont know if it's bigger or made of something that might not heat up like other pipes.
    VXII Berlina Sedan
    Jul 2006
    Quote Originally Posted by SuperSixty6 View Post
    No it doesn't - but I've had mine for about 6 months and haven't had anything sucked into airbox as yet. I suppose you could put a grate in if you wanted though....
    It is similar to the PVC pipe mod from somewhere on the forum here but the rubber hose YT use is a lot thicker and doesn't get very hot so therefore keeping the air cooler for the engine
  1. Replies: 5
    Last Post: 17-11-2008, 04:17 PM
  2. Need some help with a custom box
    By ragrim in forum Car Audio
    Last Post: 19-12-2007, 10:56 PM
  3. Custom Wgn - VX come VY
    By Driven By Shine in forum General
    Last Post: 25-04-2007, 02:15 PM
  4. Custom Car Bra
    By Doubleshadow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2006, 07:35 PM
  5. custom cai
    By SKITZ6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 02:41 PM
