Results 1 to 11 of 11
Thread: Driving Lights
    2006 VZ SS Thunder 6.0
    Sep 2008
    Mornington Peninsula
    Default Driving Lights
    Im thinking of getting driving lights for my car and i just have one quick question:
    Is it possible to hardwire daytime running lights to the parker lights, so when you turn your parkers on they come on and when you turn your headlights on they are still on because the parkers are still on and without a fuse blowing or something. Or do i need to get the whole kit with the relay and everything?
    sorry for another thread on this.
    Thanks.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    No, it is illegal. Driving lights have to be wired so that they only activate when high beam is selected. You will need a relay wired to activate from the high beam 'active' wire.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    You should reword your post so you don't get the standard 'its illegal' crap as above!
    I think you mean daytime running lights!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    usually the law is that they must be on a switch, some other states may also require they be connected to high beam.
    The Black Beauty
    Sep 2008
    thanks stealthy, i should make it clearer. Ive been reading other posts and these people keep saying its "illegal", how come the majority of recent cars come with them and use them during the day, ive seen the local boys in blue use them during the day. Anyway is it possible?
    vx berlina
    Oct 2006
    Quote Originally Posted by aone View Post
    when you wire up the relay off the 4 post one is earth. one is power to the battery, two ore one to lights, now wire the remaing power wire to your parkers power wire,so when you turn your parkers on the day time running lights work(spoties) work
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Also keep in mind that the head lights and parkers and etc are all negatively switched. I.E. They have constant +12v to them all the time and the switch allows earth through.
    It shouldn't be too hard to tap into the wiring that goes to the head-light to get it working but bear in mind you may require a separate switch to turn them off if the police believe they are fog lights
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    Sep 2008
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Running driving lights (Fog lights) in any weather except adverse weather is an offence. Keep this in mind.
    Now the definition of adverse weather anyone??
    STEALTHY™'s Avatar
    Jan 2005
    We cleared up before to keep that crap out of the thread mate
    cheers sexy
    sixes's Avatar
    sixes is offline UTEPILOT
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    Sorry, I have to add my 2 cents, Hope this clears things up
    Pasted below is an explanation as a lot of people seem to get Fog / Spot / DRL's mixed up . . .
    Daytime Running Lights
    Daytime running lights (DRLs) may be fitted to the front of a vehicle to increase its visibility to other road users during the daytime. They should not be confused with driving or fog lamps, which although similar in appearance are not designed for use in clear daylight conditions and are more likely to cause glare or annoyance to other motorists. These are around 1000 candela output. (Brighter than park lights but less than low beam output), they are designed to accentuate the front of the vehicle. These illuminate when the vehicle is running, hence the name, running lights. Similar to the Volvos you see driving around with their park lights on, same principle.
    Fog lights and Driving lights
    Fog lights are designed to improve the visibility of the road directly ahead of the vehicle during fog / rain. To work effectively these lights must be fitted with the specified globes and correctly aimed. It is now illegal to use front fog lights during normal weather conditions, as of June 2008.
    Driving lights / Spot lights are fitted to provide more light, particularly for when driving in country areas. These lights are wired up so that they switch off when low beam is selected. Driving lights are designed to supplement high-beam headlights. The light output is intense and projects well down the road.
    To get an idea, look here for an example http://www.desktopcar.net/wallpaper/...narocv8-03.jpg
    Styled by Holden, Powered by Chev
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. Replace fog lights with driving lights?
    By Cav in forum Electrical Wiring / Questions
    Last Post: 25-10-2006, 08:12 PM
  3. Need help with driving lights
    By surrealistic in forum Electrical Wiring / Questions
    Last Post: 06-05-2006, 10:46 PM
  4. Driving Lights in a VN V6
    By LiLEd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2005, 11:02 PM
  5. FS: Fog/Driving Lights
    By Bec in forum Parts And Other Items For Sale
    Last Post: 08-01-2005, 06:50 PM
