Results 1 to 9 of 9
Thread: Finally Fixed That Front End Shudder
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Default Finally Fixed That Front End Shudder
    Just quickly , I have been trying to get rid of my front end ( so i thought ) shudder for a couple of months now . My VX used to shake really bad at 70 kay and above under brakes .I have replaced the front pads and rotors had wheels balanced changed the radius rod bushes . I finally went to a brake place and they put the car on the rollers to check it . They put the front wheels on the rollers and checked the front brakes at various speeds and they were ok . Then they done the same to the rear wheels and when they applied the brakes at 80 kays the car started to shake .So two rear rotors and a set of pads later all is sweet. The mechanic said its amazing how many people come in here with what they think is warpped front discs when the problem is with the rears.
    So if any of you guys have a VT VX with the same problem get it checked out first before you start spending $$$$$$s it might be your rear discs
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    problem's with the rear!!
    as i said before "look at the gear stick more movement under brakes"
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Juztin's Avatar
    Juztin is offline Bigmacs everywhere
    VT II 99', S Pack.
    Sep 2008
    Cheers mate i also have a shudder at that speed.
    Its an annoyance but i dont have the money to get it fixed.
    Apart from being annoying it can't damage your car or create any more problem can it?
    Sorry for the bad question =P...but im still learning haha
    NVE_069's Avatar
    NVE_069 is offline Vx Calais / Ve Berlina
    Vx Calais LS1 / Ve Berlina V6
    Mar 2005
    Got this problem atm i got 2 front rotor's fitting them friday now you got me worried lol. its ok I was gunna change them all anyways so if this is the case so be it unless I know ill have all new brakes and rotor's
    Always In Construction Mode!!!!!
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by Juztin747 View Post
    Could be a problem if you have false teeth lol, But seriously anything that shakes your car can't be good for it .
    Juztin's Avatar
    VT II 99', S Pack.
    Sep 2008
    NVE_069's Avatar
    Mar 2005
    Just changed the front rotor's and the damn thing still shakes hahaha will be doin the back anyways but thought it was the fronts. No money lose tho as I was doin all four.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Just a quick note , Don't forget to back off your handbrake if you are having trouble geting the rotors off. The rotor has two rubber plugs in them . turn the rotor around till the rubber plug is at the bottom then pull the plug out and insert a small screwdriver to back off the adjusting screw.
  1. I've finally fixed an annoying coolant leak V6 commy
    By auc05l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2006, 04:37 AM
  2. front strut shudder...
    By vnstu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-06-2006, 06:47 PM
  3. Finally fixed the throttle body to open fully
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2005, 01:36 PM
  4. Front end shudder at speed
    By Pretender in forum General
    Last Post: 28-10-2005, 08:57 PM
  5. front shudder
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2004, 08:47 PM
