Results 1 to 2 of 2
Thread: Bonnet won't open
    VT Executive S2
    Oct 2007
    Croydon, VIC
    Default Bonnet won't open
    OK, I was doing some work under the bonnet when I stupidly left a spanner sitting on the left hand side in front of the battery when the bonnet slammed shut accidentally. At first I thought it'd be a case of simply pulling the release again, but the release pulls (has tension) but won't click.
    The bonnet is closed completely on the opposite side, but on the side with the spanner jammed under the bonnet is raised about 5mm and I can see the spanner sitting there.
    I've tried wedging it out with a screwdriver but it's jammed in tight. I've tried coming from underneath and playing with the catch, but I don't think that's the problem.
    Any suggestions?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Try getting someone to push down hard in the centre of the front of the bonnet (about where the badge is) while you pull the lever.
    MY RIDE
  1. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2012, 11:10 AM
  2. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  3. I can't open the Bonnet
    By baryscommodore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2009, 08:42 PM
  4. Help getting bonnet open
    By obsessed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 09:11 AM
  5. My bonnet doesn't open, at all!
    By str8up in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2005, 07:25 PM
Tags for this Thread
