Results 1 to 4 of 4
Thread: 01 wh v6 intermittent no idle
    wh statesman v6
    Jan 2009
    Default 01 wh v6 intermittent no idle
    Very intermittently my 2001 wh v6 will not idle at all, runs fine so long as you keep your foot rested on the accelerator. Also intermittently misses but not at the same time and more frequently than the idle problem. Also intermittently struggles to start, sounds like it has a flat battery but lights work fine and battery has power so far has always started.
    Have replaced fuel pump and filter, plugs, leads, coil packs and dfi, cleaned throttle body, replaced key, replaced battery, checked alternator output.
    Also can hear a very slight rattle in the engine (possibly timing chain) when accelerating up hill, is fine under full acceleration on level gound.
    Has me beat, any ideas would be appreciated.
    wh statesman v6
    Jan 2009
    Ok I beleive the non idleing is due to the computer, it seems that you can trick it to idle again by getting it started with your foot rested on the accelerator and then let off ever so slowly, holding the accelartor steady if it sounds like it is going to stall, until it is fully released and the car is idling again.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jem001 View Post
    It could be the IAC valve that is the problem. Often a good clean with carby cleaner can fix them.
    MY RIDE
    wh statesman v6
    Jan 2009
    cheers, I will give it a shot
  1. intermittent wipers
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2009, 07:48 PM
  2. intermittent miss at idle help
    By danny1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2008, 09:47 PM
  3. Intermittent idle problem
    By Fr3ak+-- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 01:34 PM
  4. Intermittent Rough Idle
    By jonesz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2007, 07:52 AM
  5. Intermittent Air Con VN
    By Elvis-in-OZ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:14 PM
Tags for this Thread
