I have had it re-gas twice now and still not workin, guys at work say that i should replace compressor, receiver dryer and the tx vavle??
I would suggest you get an aircon shop to do a high-pressure nitrogen test (about $30 plus labour) to make sure you definitely have no leaks, before you spend on the others.
I had my VT regassed in Feb 08 and again in Dec 08 (by the same aircon shop) as it ran out. Second time round they did the Nitrogen high pressure test and found two leaks (they told me it was "leaking schroider valves at ports"). Don't ask me where/what the hell that is i have no idea! Other than some unrelated intermittent electrical/fan issues, my aircon works perfectly so far.
The above may or may not fix your problem, but it's worth a try.
Ok forgot to say that we gasd it at work and afta evaucating it, try gasing it and the compressor just didnt take the gas according to the gauges
