Results 1 to 6 of 6
Thread: VT V6 errors need help
    VT S V6 Manual
    Aug 2008
    Default VT V6 errors need help
    ok i have a 98 vt series 1 v6 manual running on straight gas it has a unifilter rampod and a sports exhaust now i have noticed the fuel economy sucks at the moment it is getting about 16L/100kms in the city and abou 12L/100kms on the highway so i check the error codes and it came up with:
    19 TPS (sticking open)
    35 idle speed error (IAC Valve unable to control idle speed)
    44 LH oxygen sensor lean signal
    45 RH oxygen sensor lean signal
    65 LH oxygen sensor rich signal
    76 AFR variation between left and right banks
    now the oxygen sensors were changed about 3 months ago so were the plugs and leads. What do i need to change to fix all of these errors? and is there a better type of oxygen sensors i could use?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by dammit_billy View Post
    I once bought cheap oxygen sensors on ebay and started getting error codes within a few weeks. Then I replaced them with better ones and had no problems.
    MY RIDE
    VT S V6 Manual
    Aug 2008
    the oxygen sensors i got werent exactly cheap they were $160 dollars for the pair from auto pro. what brand did you get can anyone recomend a good brand for the oxygen sensors?
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
    VX Executive S2
    May 2006
    Frankston South Vic
    I think my genuine holden O2 sensors were $160 ea
    what type of gas system are you running? sequential or mixer
    how is the gas system linked into ecu, can the ecu control the air/gas ratio
    VT S V6 Manual
    Aug 2008
    it is a airod mixer system with a fully intergrated gas computer i dont know if the main computer conrols the afr but i was told that the oxygen sensors have a lot to do with the system running properly so i will have to change them again. with regards to the tps and iac valves do i need to replace them to get them to function correctly or will cleaning them be sufficient
  1. CAS Errors....again
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2008, 06:13 PM
  2. code errors
    By kb6437 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2008, 02:16 PM
  3. vs errors
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2007, 06:59 PM
  4. Database Errors
    By Darren in forum Site Feedback / Site Problems
    Last Post: 26-04-2007, 08:39 AM
  5. Errors #81 & #83
    By Sylvester65 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2007, 08:14 PM
