i just installed a level 3 dash cluster to upgrade from my single window. When i turn the car on the seatbelt and airbag error comes on does anyone know why it does this and how to fix it??
You should have disconnected the battery before changing the cluster. The only way to fix it is to take it to Holden or someone with a Tech 2 and have it reset.
MY RIDE
the instrument cluster needs to be programmed to suit the airbag system in the car, this is why it has coded, the code needs to be cleared & the instruments configured correctly, including tyre size for the speedo & engine type etc.
Rob
ok no worries cheers
