Results 1 to 3 of 3
Thread: reverse gear problems...
    2003 VY
    Sep 2008
    Default reverse gear problems...
    my reverse gear is obviously slipping.. when i put my foot down in reverse slowly car starts to shudder and sit in the spot and then it slowly picks up and goes but if i put it down a bit harder it jus goes straight off
    anyway it doesnt slip in front gears or anything changes PERFECT
    so what would you guys do? fix it or leave it to jus get worse i presume?
    If All Else Fails, Then You're Probably Driving A Ford
    shaunzo101 is offline shaunzo101
    VR commodore 94 exec
    Mar 2008
    narangba, briz
    Just check the transmission fluid, even though the other gears work fine but lack of fluid causes this. But other than that sounds like the reverse gear is on its way out i'd take it to an auto specialist and see if they have came across the problem before and they may offer you some advice, that's what i would do anyway.
    2003 VY
    Sep 2008
    okay cool cheers shaunzo...
    ive done nearly 10k klms since ive had her and ive had the engine oil flushed and all that ive just never had a look at the tranny... might give it a good service aswell see what happens
    cheers buddy
  1. No 2nd gear or reverse
    By VTCommoDude in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2009, 04:39 PM
  2. Reverse Gear
    By Secki in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2008, 10:18 PM
  3. blown reverse gear.. fixing
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 04:32 PM
  4. Electrical issue in reverse gear. VL
    By vlv8vic in forum Electrical Wiring / Questions
    Last Post: 22-09-2005, 04:21 PM
  5. reverse gear
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2005, 02:13 PM
