Results 1 to 14 of 14
Thread: Installing Power Windows to VT Commodore
    VT Executive Series II Sedan V6 Auto
    Jan 2009
    Default Installing Power Windows to VT Commodore
    Can any one confirm if they have successfully converted their windows from manual to electric using the guide in the "How To's" Section?
    I noticed that the instructions are for a VN or VR/VS, but will they also be the same for a VT Sedan??
    My holden dealer told me I would need to change my BCM, but I noticed they wired the windows up without connecting to the BCM at all.
    I am keen to do the conversion but dont want to go out and buy all the gear if it cant be done.
    Any help would be greatly appreciated!!
    VT Executive
    Oct 2008
    Hey mate, I just did mine and it was real simple. All you need is the wiring harnesses for the rear doors. I was lucky to already have the wiring in the centre console. If your car doesn't have this then it may be a little harder. Just check if there is the plug for the centre console switches underneath the centre console. Any hassles or q's just PM me.
    Jan 2009
    Hey mate
    Thanks for the fast reply, I just checked and I don't think mine has a plug for the center console switch??
    There are a couple of plugs under the cover but they are all plugged in at the moment. What does the plug look like and was it already unplugged??
    I have managed to track down a wrecked VT Calais which I can get all four regs, the console switch, wiring loom from console switch & rear doors wiring looms only, front door looms have been sold...damm it.
    Is there a power window module also??? I notice on the how to do it they showed a power window module, which the console switch is wired to??
    Your help is greatly appreciated!!
    Adam
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The plug is about 1 and a half inches wide and has 8 or 10 wires attached. You couldn't miss it if it was there.
    MY RIDE
    VT Executive
    Oct 2008
    Hey mate, yeh as accentstencil said, you should see the plug right there, it wont be plugged into anything. If your car is a Series 1, the part number from Holden for the front wiring harness is 9204 7663. I had to buy mine cos no where had them second hand. If you dont have the centre console plug, I cant help you bud. Cos mine was there mine were easy to instal.
    VX Executive
    Sep 2011
    hey, im looking to install power windows on my VX executive. i have the plug for it already in the centre console. Is anyone able to help?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by domthebomb View Post
    I'm not sure what you want to know but you will need the main switch block, door looms ( I have some for sale if you are interested) rear door switches and of course, the regulators. Since you have the connector for the main switch I would assume your BCM can handle power windows, but don't hold me to that. You will also need a relay ( not sure if there is one or two) and fuse.
    MY RIDE
    vx series 2 executive
    May 2012
    Australia
    i need some help i am changing for manuall to power windows i have changed all wiring in doors center button nd put all fuses in oh nd i am only doing front doors in my vx my prob i have is i have no power to the doors can anyone help plz
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    Quote Originally Posted by tezzr34 View Post
    have you put the relay in if there is 1? i think its called drivers window relay..
    Wtb Parts for Vt, Pm me what you've got to sell!
    May 2012
    Australia
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    is it just the drivers door or all?
    May 2012
    Australia
    just drivers side as thats the only one in atm do i have to have both in for the window to work
    98 vt executive 9c1
    Jan 2012
    Harden Nsw
    i dont know bud... but after i put all mine in the passenger and the 2 rears worked fine.. the drivers would only go up, not down.. followed the power up to the bcm but couldnt find the power coming out of the bcm to run the drivers window down... so i ran wires from the 2 wires that operate the drivers window to the motor plug itself.. dodgy but it works haha
    May 2012
    Australia
    ok thanks man would u no wat wires to the button so i can run it of the button
LinkBacks (?)
  1. installing power windows
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2011, 10:23 AM
  2. installing power windows into 97 vs ute
    By supervsute in forum Electrical Wiring / Questions
    Last Post: 11-05-2008, 09:50 AM
  3. Installing power pack stuff, Elc mirrors, windows, antenna etc
    By Wingnut0021 in forum Electrical Wiring / Questions
    Last Post: 29-01-2006, 12:06 AM
  4. Installing Power Windows
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-06-2005, 09:24 AM
