Results 1 to 5 of 5
Thread: ignition barrel
    VT EX S1 3.8L
    Jan 2006
    Default ignition barrel
    Hi the barrel on my vt just started to spin still works but i have to turn it back every time i start it or the starter motor stayes on i got i price from holden for $65 for a new barrel and they say i will have to get it re coded i cant see how this is true as it is the same key and it is only the center barrel not the contacts were the key touches if ther is any body who has had the same prob can you tell me if you hadto get the barrel keyed to the oridginal key and re coded any input would be great as i am a bit tight on funds after chrissy like all of us and no ot at work
    thanks heaps
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by 6-PAC-ATTACK View Post
    thanks heaps
    I had the same problem and it was the ignition switch. The switch has the spring which makes it return, not the barrel.
    MY RIDE
    VK V8 & VS EX-COP
    Dec 2008
    VT EX S1 3.8L
    Jan 2006
    THANKS HEAPS told holden my prob they said i needed a barrel are they ez to change diy and how much for a new switch
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The switch cost me $27.10 about 2 years ago. Following the instructions in my Gregory's workshop manual, installing it was easy. I recommend you buy one if you plan on doing your own repairs. Pick one up for around $40.
    MY RIDE
  1. Ignition Barrel
    By vt com in forum General
    Last Post: 01-01-2008, 02:10 PM
  2. ignition barrel
    By jeddabum in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-11-2007, 10:00 AM
  3. ignition barrel
    By 235rwkw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2007, 07:26 PM
  4. ignition barrel
    By ssmartie2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2006, 09:35 PM
