Results 1 to 12 of 12
Thread: Urgent help...vt power window coversion
    VT Executive Series II Sedan V6 Auto
    Jan 2009
    Default Urgent help...vt power window coversion
    I am in the process of converting my VT Exec manual windows to power using the How To's guide.
    I have just discovered my BCM is a low model unit and will not take power windows. As I do not want to go through the hassle of swapping the BCM, I was going to try using the wiring diamgram as in post 44, where you use a Power Window Module out of a VN/VP/VR/VS and avoid the windows being wired to the BCM.
    Before I go and buy one, will this work with my VT?? Is there any other parts I will need to make it work??
    VT Calais parts I already have:
    *4 power window regs
    *Main Console Switch
    *Rear Switches
    *Wiring Looms
    Is there another way to wire it up without the use of a module?
    Many thanks in advance!!
    Jan 2009
    I was thinking about hardwiring the regulators to the switches and not even worrying about the power window module, obviously I would use a 20A inline fuse and some power window relays.
    Does anyone know where the relays should go??? The holden wiring diagram shows the relays on the positive power before the switches, but a mate reckons they should go after the switches and before the regs??? Not sure...any help...anyone?????
    Cheers Adam
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    im no electrical expert - far from it but i would say the fuse should be before the whole set up.
    somewhere between the power supply and the first link of the system..
    wouldnt it just be easier to get the proper BCM and have Holden do their magic to it so its basically a factory system?
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    If you hard wire them, you won't get auto-down/up and you might burn out the motors pretty quick if you keep the switch held down after then reach fully open/closed.
    VR TWIN TURBO V6
    Feb 2010
    Default vt exec conversion 2 a vt ss
    i have a written off vt ss gen 3 auto that im transfering to an executive body but i want to use a 65spd gearbox instead of the aauto box. the 6spd is off a gen3 vx any tips ??
    VX Executive
    Nov 2008
    Bolton point Newcastle
    Quote Originally Posted by adstarr View Post
    Cheers Adam
    I hard wired mine in my old VS worked fine but it keep blowing fuse so I replaced it a Holden circuit breaker and it worked great
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    Quote Originally Posted by twinturboV6 View Post
    wrong thread, but i dont think it would be a hassle,
    anyway, i am n ot sure if the wiring wold be different or the same, but i did this w/ my neons, i have them wiried to indivual switches that are connected to the battery so they can turn on and off w/out the car being on. but the windows mihgt require more power
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    when i installed my power windows all we did was used all the stock wiring, except for the drivers window down wire, i had to cut that, and re wire it straight to the drivers window down wire on the door loom, bypassing the BCM completely, this allowed me to use the drivers windows without the BCM. Was a simple 2 minute job to fix the drivers window.
    vx
    Nov 2009
    Quote Originally Posted by ruggj View Post
    hey could you do a small diagram of the method you did it and take a photo and put it .....
    VT HBD LS1, VL calais project
    Nov 2009
    SE bris
    hey mate, im tryin to do the same but it still wont work when i bypass it.. got a pic or diagram to do this??
    Larry
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    i'll need to have another look at it and get some pictures etc. but i think its the G/B wire your after from the window switch, and again on the door loom. good luck
    oh and make sure you have all the correct relays for the windows, as your only bypassing with 1 wire, (just the wire that the bcm doesn't have in it) the rest of the wires still need to meet up to the relay, so you still need a drivers window relay, which i attached in case some of you need to buy new ones
    Attached Thumbnails Attached Thumbnails Urgent help...vt power window coversion-drivers-window-relay.png
    Nov 2009
    SE bris
    cheers mate, i finally got it workin this arvo.. thanx for ya help
  1. PLEASE HELP!!! *URGENT!* - VT Electric window problem!
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2009, 03:39 PM
  2. URGENT HELP NEEDED - REPLACEING Drivers side window in VS
    By ben_vs_manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2008, 05:04 PM
  3. Power steering URGENT HELP
    By orreal511 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2008, 06:26 AM
  4. Manual coversion for a VS
    By nmd_nathan in forum V6 Development And Modification
    Last Post: 25-08-2006, 09:22 PM
  5. F/S: A4 195kw Coversion..5.0L VT
    By slowr8 in forum Parts And Other Items For Sale
    Last Post: 17-06-2006, 05:01 PM
