Results 1 to 7 of 7
Thread: Reco motor install on Monday
    98 VT Wagon
    Oct 2007
    Default Reco motor install on Monday
    Hi all, on Monday i have my 98 VT Wagon going in for a reco motor replacement, also a reco trans replacement. The original motor has done 300,000 and has a blown head gasket. Yes i know i'm spending a sh!t load and probably it will work out to be more than the cars worth but my car is my hobby and i don't want to part with it as i have had it since new!
    I understand when they do a reco motor they use a fair few components off the original motor. I already have been told to get the injectors re-conditioned before they go in the reco motor, i have asked for a new water pump and thermostat, I have also requested platinum plugs and new top gun leads. As i said the original motor has done 300,000 k's so can anyone give me some advice on what else i should be asking for or considering prior to them starting work on it Monday.
    Cheers, Daz.
    vt s/c spak
    Apr 2007
    Quote Originally Posted by dazza33 View Post
    Cheers, Daz.
    I would be asking them what is goinng in the reco motor, it should have new big end, and main bearings, cam bearings.
    heads should also be recoed, there should be new lifters, cam chain, pistons , rings...etc...
    the cylinders should be rebored?, or honed......deglazed.
    waterpump and thermostat should be standard inclusions.....
    davo......
    98 VT Wagon
    Oct 2007
    VZ SV6
    Oct 2008
    Newcastle NSW
    Heater tap, rear main seal, sump gasket, hoses etc (imagine blowing up a new engine coz of a failed top radiator hose...)
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Hi all, on Monday i have my 98 VT Wagon going in for a reco motor replacement, also a reco trans replacement. The original motor has done 300,000 (ecotecs usually last a lot longer than that with no need for a rebuild) and has a blown head gasket. Yes i know i'm spending a sh!t load and probably it will work out to be more than the cars worth but my car is my hobby and i don't want to part with it as i have had it since new! (most people on this forum have a car for a hobby... doesn't mean you should be prematurely rebuilding a V6 automatic, of all things!!)
    I understand when they do a reco motor they use a fair few components off the original motor. I already have been told to get the injectors re-conditioned before they go in the reco motor (they should include this in the price, they are making enough off you already that it's almost criminal to ask you to do that yourself), i have asked for a new water pump and thermostat, I have also requested platinum plugs and new top gun leads (completely pointless on a stock V6). As i said the original motor has done 300,000 k's so can anyone give me some advice on what else i should be asking for or considering prior to them starting work on it Monday.
    Cheers, Daz.
    just my thoughts
    WTB: mulberry VN interior parts
    98 VT Wagon
    Oct 2007
    I got a price of around $2000 to $2500 to do the heads, a reco motor $2700. I just figured this was the better option for sake of longevity. Plus i can now look at mods within the motor rather than bolt on ones. Like i will consider higher ratio roller rockers now as where i wouldn't have before.
    The torque converter was slipping and the transmission was in limp home mode after 15mins. the oil was also burnt.
    It is not completely stock as in the memcal has been reprogrammed, CAI, 2.5" exhaust, high flow air filter and a upgraded throttle body. Didn't mention this at the start as i was more concerned with the block and heads in my original post.
    To true, it's a given i suppose.
    Thanks for everyone's comments though, duly noted.
    Daz.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I got a price of around $2000 to $2500 to do the heads, a reco motor $2700.Seems quite expensive.. mate had his 3800 rebuilt for $1800.. bear in mind you can pick up a second hand ecotec for a couple of hundred dollars. I just figured this was the better option for sake of longevity. Plus i can now look at mods within the motor rather than bolt on ones. Like i will consider higher ratio roller rockers now as where i wouldn't have before. Honestly, consider doing more than that mate, like different pistons, cam, might as well build something half decent for your money. Roller rockers you can do while the motor is in the car, they don't really count as an internal modification imo
    Sounds like you should be rebuilding the transmission then, that's fair enough
    That's still pretty much stock dude, definitely not worth those plugs, absolute waste of money
  1. vs reco motor
    By broady01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2008, 09:45 AM
  2. F/S 308 Starter Motor Reco
    By Sik_Cordz in forum Parts And Other Items For Sale
    Last Post: 25-08-2008, 06:57 PM
  3. Reco motor in, lifters noisy!
    By Macca177 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2006, 10:00 PM
  4. Reco motor compaines
    By Macca177 in forum General
    Last Post: 13-11-2005, 06:00 AM
  5. Vn 2 Vs motor install
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2005, 02:17 PM
