Have had a vx for a few months now and the drivers power window hasnt worked since i got it. It makes a clicking noise which sounds like it's coming from the relay so i replaced that today and it hasn't fixed it. Any ideas what it might be?
Could be broken wire in the rubber boot that goes from the body to the door or maybe the regulator motor has packed it in. It's not the switch since it make the relay click. You can connect 12 volts directly to the motor to see if it works but it means removing the door trim and peeling away some of the plastic behind it.
MY RIDE
Cheers, I'll check them tomorrow.
