Results 1 to 4 of 4
Thread: Just bought a 99 VT S - ringing trans!!!
    May 2008
    Default Just bought a 99 VT S - ringing trans!!!
    any one diagnose the following: when idle in neutral transmission is quiet, but when idle in gear sounds like a ringing/slight vib from the front of the car. Cant really hear it at speed. mounts have been done by previous owner. Anyone know what this could be? serious, common?
    thanks
    May 2008
    Default Belt tensioner?
    looking over the forum, anyone know how I can sus out if it is the belt tensioner or something?
    VT 2
    Nov 2008
    Belt tensioners are easy. With the engine running, place a screwdriver blade hard against the pulley axle. Stick the other in in your ear. This is a crude stethoscope. If you can hear the bearing grinding, its the belt tensioner pulley.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Engine cover all secure? Forgot to put the engine cover onto a GenIII securely, started it up, idled fine but as soon as i put the car into gear there was a vibration. Finally clicked, nipped up the 4 fasteners and came good.
    Even if the cover is tight it may still be vibrating.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. faint ringing noise after brake service
    By Lukey75 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2008, 07:19 PM
  2. Ringing/Tinging Noise in Engine Bay, SV6 Manual
    By esp22 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-05-2008, 10:46 AM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. Ecotec Ringing Pulley
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2004, 10:10 PM
  5. I Just Bought A Vk
    By Jase VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-09-2003, 04:00 PM
