Results 1 to 13 of 13
Thread: commodore low speed fan on all the time?
    99 VT Commodore Executive
    Jan 2009
    Alice Springs, NT
    Default commodore low speed fan on all the time?
    I recently purchased a 99 Commodore VT Executive, auto, v6, etc..
    The low speed fan relay was missing when I bought it, and i bought one and put it in.. I now see why the relay was missing - it stays on all the time.
    The high speed fan operates properly, turning on when it gets hot or when the a/c is on. It cycles normally as far as I can tell.
    However the low speed fan stays on all the time, even after the car is shut off.
    From my searching in the forums, I gather it might be two things - either a bad ecm, or a bad coolant temperature sensor. Does this sound like a fair diagnosis? The temp. gauge on the dash works properly, and I recall reading that there are separate sensors for the gauge and the fans....
    Any advice?? I don't want to pour too much money into it.
    99 Commodore VT Executive...
    VZ SV6
    Oct 2008
    Newcastle NSW
    Check fault codes - check engine light for coolant temp sensor failure or similar.
    If you unplug the sensor wiring then start the car (with it cold ideally) after 6 seconds the low speed fan should come on then 12 seconds later, the high speed fan if the fan circuit is working correctly according to the gregory's.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Yes like alex2_s says the relay if working the low speed fan should come on in 6 seconds and then high speed in 12 seconds, if not then you may of gotten the relay around the wrong way check the contacts, if not then try replacing the fan it might be stuffed.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Jan 2009
    Alice Springs, NT
    Ok will try pulling the sensor wire. I am not in doubt of my skills yet, so I'll hold off on the mechanic right now, but reserve the right to at future times
    Thanks
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by fitz_vt View Post
    ..... if not then try replacing the fan it might be stuffed.
    No need to replace the fan as it is working.
    MY RIDE
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by accentstencil View Post
    yeah thats a last resort replacing the fan but the relay is probably the cause of it, its probably really dodgy and keeps sticking i had one of those had to replace it...
    vt commodore
    Apr 2009
    hey mate ive got the same problem at the moment with the same model car i actually rang an auto elec an he said the relay is probly wrong ,i got the old original relay an the new one i brought an he was right the 30 pin on the relay is in the wrong spot this is the earth pin but im still having troubles finding the right relay they look the same and fit in but all the pins a numbered an all the ones have the 30 and 86 pin in the wrong spot does anyone know what is the correct relay model i need ???
    VT Berlia
    Aug 2007
    Belgrave, Victoria
    i had the same problem about a mouth ago, I changed the relay with one from autobarn and still had the problem.
    Still convinced it was the relay i went to holden to get the genuine one, and have not had a problem since.
    i would have thought that the genuine one would cost more, but they were both the same price. Yet the autobarn relay did not fix the problem
    ( TYCO model no. V2314-K55-X406 92092444)
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    The correct Genuine radiator low fan relay is
    part # 92092445.
    I like my roo well done
    VT Berlia
    Aug 2007
    Belgrave, Victoria
    Quote Originally Posted by WAGON MAN View Post
    part # 92092445.
    92092444 is the one that i have, that was given to me by holden. the guy
    even looked it up on the computer. the old one i had was a siemens 92050455,
    but he couldnt fine that one. so i told him it was for the low speed fan and he
    gave me that one.
    just go to holden and tell them what the relay is for and
    they will look it up and give you the correct relay
    vt commodore
    Apr 2009
    hi in reply to my earlier post i got the correct relay from holden all working fine for about a week then it starts to overheat again !! I started the car while pushing mode and up to get the temp reading an just let it idle then with the temp reaching 100 C. and the neither fan kicking in ,the reseviour started to overflow form the radiator ?? but when i turn on the air con both fans start.
    Also where is the sensor wiring to unplug to test for the 6 seconds low speed and 12 seconds high speed ?? but when i turn on the air con both fans start.
    Also noticed my radiator water is really dirty like rust could that have stuffed up my termo stat ??
    vt
    Mar 2012
    brissy
    vt
    Mar 2012
    brissy
    if fan are working with this test then what would be the next thing to check for
  1. FS: VT Commodore 5.0lt V8 - 5 Speed (Adelaide)
    By 13bbprx7 in forum Vehicles For Sale
    Last Post: 12-11-2007, 08:33 PM
  2. FOR SALE: 5 speed VT commodore
    By chevy_big_block_bro in forum Parts And Other Items For Sale
    Last Post: 04-08-2006, 06:09 PM
  3. Speed Sensor for VN Commodore
    By bjj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2005, 02:55 PM
  4. want a commodore 5 speed vn vr vs
    By tcm400 in forum Swap / Wanted to Buy / Trade
    Last Post: 22-07-2005, 01:26 PM
Tags for this Thread
