Results 1 to 4 of 4
Thread: Replace brake globes VX Commodore S
    VR Calais
    Feb 2008
    Default Replace brake globes VX Commodore S
    I need to replace a brake globe on my 2001 Commodore S VX. Can someone please tell me how to do this? I can not see an easy way in to it. There are two screws holding one end of the light cluster in but it still will not come off (do I force it some more?). Thank you for any help.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Are you working from inside the boot or on the outside trying to take off the plastic lens?
    VX Executive S2
    May 2006
    Frankston South Vic
    undo the 2 screws then slap (with palm of your hand) tail light housing outwards (sideways) do not try and pull backwards
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Undo the two screws. The outer side is held in by two plastic prongs. It's meant to be a tight fit to get it out. Just do as said above. Then once out, simply swap the globes over, put the prongs back in first, knock them home and do up the screws.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. How to replace tail light globes?
    By DonFrancis in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-01-2009, 10:46 AM
  2. Replace burnt Globes - Power Button & A/C Switch
    By mourati in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-08-2008, 12:46 AM
  3. how to replace sun visor globes
    By gottavecalaisv in forum The Pub
    Last Post: 14-08-2008, 08:31 PM
  4. Can I replace globes with LEDs in stock Eurovox deck?
    By holdenrules in forum Car Audio
    Last Post: 28-08-2005, 12:37 PM
  5. Tail / brake light globes blowing
    By pwill in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2004, 03:05 PM
