Results 1 to 10 of 10
Thread: 1/4 mile times
    VP Commodore
    Aug 2008
    Default 1/4 mile times
    hey guys,
    i took my stock standard VT s pack 98 down the drags last night and my best time was 16.71.
    just wanted to know if this is around about and average time for these types fo cars???
    let me know wat other times have people gotten...
    VP Executive R-spec
    Jan 2005
    Friend of mine runs 10.1 on the 1/8th mile to compare you will have to look at the 660 foot mark on yout time slip, but I would say his time would be a fair but quicker
    VP Commodore
    Aug 2008
    my 660' was 10.41 second. so yer bit quicker than mine.
    was his car stock?
    ohh and by the way, wat are some things that i could do on the day to make it any quicker? does things like spare wheel, tyre pressure, air filter seem to make any differance.
    sway9 is offline The Rejectz Commodore
    99 VT, Mazda 3 SP23, Hyundai Getz 1.4ltr
    Dec 2008
    Albion Park NSW
    mine was running 17.1 stock after tune service a few g's behind the engine its only pullin 14 flat for a PB i think mines brokended
    On the look out for my new VT 98
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    KnN Air filter, Iridium spark plugs and premium petrol apparently will give you a little more power also make sure you have your tyres at the right PSI, remove your spare tyre, anything that puts weight on your car
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by pmac View Post
    was his car stock?
    Yeah his is stock, 10.41 should end up faster than 16.7, should be more like 16.3/16.2 how come your loosing so much on the top end?. 10.1 should run a fairly easy 15. Like 15.7 or 15.8. Spare tyre can be worth nearly .1 on slower cars. Air filters can cost you half a tenth if they are dodgy ones etc. You should run the most tyre pressure you can and still get full traction. Also check you brakes for drag. Have all your wheel bearing adjusted just right etc etc. All those little things add up, that's how I get mine to run good times just lots and lots of little things being right
    VH and VT S2 Berlina ecotec
    Aug 2007
    Brisbane-northern suburbs
    i just took my stock vt. all i've done is high flow filter and striped out the boot, i only ran once and think i could have got better but i got a 16.6
    VT Berlina 07's Avatar
    VT Berlina 07 is offline 15.37 @ 147 KPH
    96 EF2 Futura I6 Auto
    Apr 2007
    Sydney, NSW
    16.7 isnt to bad depending on km's it has and weight. when they came out new they only did 16.3-16.5 and 0-100 in 8.8 so thats not too bad. also mine used to have less power when it was hot outside, them seem to suffer from heatsoak really bad
    96 EF2 Futura I6 Auto Sedan Superlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD 15.37 @ 147 KPH
    Aug 2007
    another thing i did was seal up the air box, like where the cai goes into the corner of the box, it was all loose and allowed air to get in the gaps. yer mine feels 100% quicker on a cold night, it quite amazing how much quicker it feels...too bad my run at willobank the temp was in the mid 20's
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    i go to the strip with my peterol meter saying 60kms till empty, take the filter out of my otrcai, strip out the boot and run 25psi in the rear with 215/15/s... also if your running mags on the front they are heavier so swap them with stockies too...
    after that i still run an ok time for such a heavy car...
    ET: 13.326
    TS: 108.77mph
    RT: 0.043
    60': 2.117
    330': 5.734
    660': 8.698
    660' speed: 139.70kph
    1000': 11.127
    result: win :-)
    Going where no late model stato/caprice has gone before.... GAME ON!!
  1. 1/8th mile times
    By Satanic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2008, 08:28 PM
  2. 1/4 mile times
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2006, 11:24 PM
  3. VY SV8 M6 1/4 mile times?
    By JMiller in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-06-2006, 12:00 AM
  4. V6 1/4 Mile Times
    By STROKEDVR6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2006, 01:15 PM
