hey all
i am in need of help bad my vt on my oil filter it keeps blowing out the seal making me lose oil every where i got told its cause the oil pressure is way to high is the problem or is it some thing elcs and if that whats making it blow the seal is there any way to fix it or am i needing to look for a new motor
so any help would be good thanks
adam
Who changed ur oil filter?
Check the seal off the old filter isnt stuck to the block.
And put another new filter back on it (not the one that keeps blowin out)
When you put the new filter on use a bit of the new oil on ur finger to rub onto the filter seal.
Then hand tighten till you feel it grip then another half turn.
IS it high oil pressure or pressure build up, I have had this promblem in the past with my 455 pontiac motor the dip stick use to blow out with oil going everywhere,
some possible causes are excessive blow by( rings),overfull oil or pcv blocked
i changed the oil filter and i didnt leave the old seal in all ways make sure i get that out,so i think oil is pumping to fast or somthing making it blow the seal
What? You took the oil seal off the filter and can't work out why it blows oil?lol
Nice try![]()
VYII Calais L67
|VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
Mods to come | VY Map Reading light/Sunnies Holder|
"Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
i have replaced the oil filter now wanting to know is there any way in slowing down the oil pressure cause my mate told me thats whats the cause of the oil filter seal blowing,he said there is a nut or somthing near the oil filter with a spring on it and if the spring is fully open it causes the oil to flow faster dose any one know where this nut and spring is or is that bull sh*t about that tryin to do every thing my self as money is very tight cause of wedding
Have you double checked that you havent over filled the engine with oil?
yer atm there is no oil in it, but every time i put oil in it and start it, it blows the seal on the oil filter but i got told that the regulator pressure spring might be stuck open allowing it to blow the seal. is there a way to fix that easily?
Adam
I assume your car is a V6? If so, the oil pressure regulator is located behind the mounting plate that takes the oil filter. The mounting plate is actually the oil filter adaptor. Here's what you do.
1 To get at the regulator, drain sump to reduce any chance of excess oil overflowing. Edit - just re-read your post - you said sump is already drained. Ignore step one.
2. Remove the four bolts holding the oil filter adaptor to the block. There is a gasket between the adaptor and the block, so have a new one ready before starting the job.
3. As you remove the adaptor, the oil pressure spring and valve will also be released.
I'm not sure why your oil is pushing out like it is - it sounds like it could be excessive crankcase pressure, which someone else has said could be caused by broken rings or excessively scored bores (or both). Is this the only place that the oil pushes out - is there any sign of it escaping out the oil filler cap or via the pcv? Is there excessive oil inside the throttle body - this would also indicate excessive blow-by from rings or bores.
The spring is not adjustable by means of a screw down nut or any other means. It can lose tension over time, which means it allows the valve t open at too low a pressure, which is possibly your problem.
Once you get it out, see of you can compare its length to a new spring. Unfortunately, my manual doesn't provide the dimensions of the spring. If it varies at all from the new one, replace it.
Good luck.
this is regarding ^^^^^ i have put yet another oil filter on with new oil and yeah all fine,but cause my car is a man(5speed) soon as i put it in gear and go to take off it blows the seal but no oil comes from filler cap or pvc but i rung up plaza holdens today and a guy said by the sounds of it,its the valve spring so thats my next thing to fix
The oil gallery from the pump to filter is in NO way connected to the open crank case, so case pressure will not come onto the equasion!
If you are SURE the filter has been correctly installed, the only way there can be excess oil pressure blowing the filter seal out is if the 'oil pressure relief valve', found behind the filter adaptor in the timing cover, is not moving back, prehibiting the excess oil from the pump to discharge back into the sump. If the spring has collapsed, your oil pressure to the filter would be LOW, if the piston has stuck closed, your pressure would be HIGH, probably high enough to blow out the filter seal.
This oil pressure relief method has not changed from the first 1948 Holden!
Just a thought, if the crank case pressure was so high as to blow out the filter seal, would this same pressure not send the dip stick through the bonnet? or blow out the other engine seals??
i have taken off the oil filter adapter plate just wondering how to tell weither the valve spring is broken or damaged cos it is still in the same spot and i cant move it is there any way to get it out to look at it without taking the timing cover and everything off
calaber, thanks your way helped me out alot.
adam
Hey Adam, I just had a look in my workshop manual and it says to just remove the plunger and spring after the filter adaptor is removed.
It would appear that the plunger would just come out by its self, possibly being pushed by the spring. If the plunger is jambed, then the timbing cover will probably have to come off?
Can you get any movement in the plunger by pushing on it? If it is not stuck, a good magnet may draw it out.
I have never worked on a v6 pump, so I am only going by the book.
Pablo
What filter you using. Try a K&N one as bigger may alter some pressures. Also check your PcV valve as may be faulty not allowing engine to vent etc.......if oil filter is blowing from pressure, i'd be watching my other seals as well.
i have to take off the timing cover to fix it cause i carnt get any movement from the plunger and spring at all is this a hard job or should i just take it in just trying to cut cost's doing things my self but would it be easyer and faster if i just took it in????
I suggest you get your self a 'workshop manual'. It is a srtaight forward job, but the book gives a more step by step method and a few tips to make the job easy.
Pablo
