Results 1 to 5 of 5
Thread: Interesting vx problem
    vx executive
    Apr 2008
    Default Interesting vx problem
    I have a 2001 vx, dual fuel stock engine and gearbox problem is this.When driving after about 5 to 10 minutes the engine light will come as it does I notice a slight change in engine tune and also the auto shift points change it revs to about 3000 rpm before it changes into each gear. Stop the car switch the engine off then restart all is perfect for another 5 to 10 minutes then it does the same again, has anyone come across a senario like this.
    regards
    keith
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    check the error codes on your engine
    Checking error codes VT/VX
    this should tell you whats wrong in codes for example 12 is satisfactory operation which is what it should be
    Please post the codes here
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    vx executive
    Apr 2008
    Thanks for the reply, I will try and check the codes some time over the weekend.
    vx executive
    Apr 2008
    Found the problem occassionaly my car backfires when running on gas one day it backfired three times in a row and this caused the air cleaner element to almost be sucked up into the pipe that goes from airbox to throttle body put new filter on now no problem. also fixed backfiring problem changed to better quality plugs and leads.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    Good job. Gas can be a tricky one to get right. I'm glad it was something reasonably simple and that you found it before it did any real damage.
LinkBacks (?)
  1. 09-02-2009, 04:24 PM
  1. Interesting Ignition problem
    By emmalea81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2008, 10:20 PM
  2. An interesting problem with my VT
    By Trei in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2008, 06:08 AM
  3. Bit of interesting reading
    By Outlaw Torn in forum The Pub
    Last Post: 15-07-2006, 08:20 AM
  4. interesting statistic
    By Troy711 in forum The Pub
    Last Post: 16-12-2005, 06:41 PM
  5. Interesting...
    By rattattack1313 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2005, 10:34 PM
