hi all can anyone plese help, this started of as just wanting 2 extra speakers in my vx but then realised I needed an amp. I bought a 4channel amp and was told i could just pop it in my vx with no problems, well hmmmm i seem to be having a problem cos i cant , How if it is possible do I attach it, I have spent hours on this so far, ive drilled and grommited holes run cable everywhere but forgotto check that it will all plug in, grrrrrrrrrrrrrrrrrrr
cheers
jo
wow...
u should have a look at the wiring diagram for the amp. I suggest you just run the rear speaker wires to the amp and bridge the four speakers out on he other side.
This is heaps dodgey but the only real way
thanks but i ended up just buying a new stereo, a lot easier and should have better sound too,
cheers
