Hi,
I have to get my car fixed in Darwin NT.
Anyone recommend any particular companies to do it?
I am new in Darwin and not sure who is good.
Also I have never had to replace a clutch so far, so what sort of clutch should I put in it?
I am quite hard on my clutch, occasional burnouts. This one lasted 135000kms.. Is a heavy duty clutch recommended over a standard one?
What sort of money are we talking for a standard one installed, compared to a heavy duty aftermarket one? Which brand/ type should I get.
I know nothing about clutches unfortunately.
Any advice much appreciated. Cheers.
Steveo
I'll be going down the same path as you shortly with my vy v6.From what I have found out so far Exceedy do a heavy duty single mass clutch kit that replaces the std dual mass that Holden fitted.I priced 1 a while back I think it was about $1600 plus fitting, but hold me to that it was a while ago.
^^^ +1 on the product.
But talk to gslrallysport... they do a money competative price on that item i think OR there is a ebay seller eBay Australia Shop - NORTHERN BRAKE AND CLUTCH: EXEDY PERFORMANCE CLUTCH KITS, EXEDY SAFARI TUFF CLUTCH, EBC DISC PADS that do a good price on them too.
I remember when i got mine it ended up being 1000 including shipping so shop around.
Good luck
There seems to be a big variation on what Exedy charges depending on where you are in the country. The best we could do would be $1225 shipped to you. Shop around, and also play dumb and see what your mechanic would charge for the clutch. The part number you want is GMK-7353FWHD.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Thanks for that
I got a Raptor supercharger and a few other bits and pieces on my ute as well,will that clutch handle the extra power/torque or is there something a bit more heavy duty?I'm off to the drags with it in the next couple of weeks so you'll probly be hearing from me not long after!!!!
thanks for that info there gsl, i will do some research, do you have a website?
yeah bud, GSL RallySport, The Motor Sport Revolution!, or QFM Performance
or
GSL RallySport - Just Commodores
Cheers,
Greg
