Results 1 to 21 of 21
Thread: VX 2001 Dual Fuel - Vibrates like crazy when driving on petrol
    VX 2001 Commodore Exec.
    Jan 2009
    Default VX 2001 Dual Fuel - Vibrates like crazy when driving on petrol
    Hi,
    I had my VX converted to gas about 2 years ago and it drives great on gas. However when i drive it on petrol it vibrates and shudders like crazy when i accelerate between 60kms to 90 kms. It also shudders a little when stationary. This problem has been getting increasingly worse over the past 6 months. My mechanic can’t find anything wrong. I'm hoping that another commodore driver is having or has fixed a similar problem.
    Please help, thanks.
    daggett is offline Crazy Tiger
    Commodore S VT Series II M5 & VT II Wags
    Mar 2004
    Goulburn
    Jan 2009
    Jan 2009
    I had a quick chat with my mechanic & he doesnt think that would be the problem as my gas and petrol run through the same injector. He will be looking at the car on Friday anyway.
    VT V6 Executive S1
    Nov 2007
    NSW, Central Coast
    Quote Originally Posted by Barbie View Post
    If your mechanic said that, it's time to change mechanics.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    I am curious how the "mechanic" thinks the gas gets into the fuel rail to be "injected" through the fuel injector! WHAT THE!!!!!!!!!!!!!!!!!!
    Life is one big learning curve.
    Feb 2007
    Look at the outlet of your gas regulator. Does the vapour hose feed somewhere into the intake manifold or does it feed into an injector rail?
    LPG can NEVER be fed through the same injectors as what your petrol system uses.
    Regards,
    Dave
    Injected CNG, LNG & LPG: The only way to go better!
    Jan 2009
    Any suggestgens who to take it to instead of my mechanic. It has been recently serviced by the gas installer and is perfectly healthy on the gas side. Should i be taking it to an auto mechanic or straight to a holden dealer?
    commsirac is offline Banned
    vx
    Aug 2007
    The gas installer was told about the problem?
    Jan 2009
    Gas service guy has been told about the problem in the past when it was not quite as severe and he has said that the gas system is fine and he cant find any problems, got the impression from what he said that because it was only a problem with the petrol it wasnt his problem/area of expertise. it has got much worse since he last saw it a month or so ago.
    Jan 2009
    I have just spoken with my gas service centre and they said that because it is only a problem on petrol that it is best for me to take it to my mechanic. Am i doing the right thing by going to my mechanic for him to check over it? As you can tell i've limited knowledge on this.
    vs ss
    Nov 2006
    I have a vy, factory duel fuel, and is doing exactly the same I replaced the fuel filter, plugs and leads, but no good. Still runs perfectly on gas, but not on petrol. vibrations plus+++++++
    Jan 2009
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Ditch the gas and just run petrol or ditch the petrol all 2gether that'll fix it.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  15. #15
    vs ss
    Nov 2006
    I guess the next thing is to get the injectors cleaned. Its funny though, cos' now my dash keeps alarming saying fuel guage error, and drops power for a split second before correcting itself and working fine again. It sis doing this more frequently now. I don't know whether the two are related or not. Any clues on the error messages anyone?????
  16. #16
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The gas might not be turning off when you switch it to petrol, so it is getting both gas and petrol which will flood the engine. The gas solenoid might not be closing off fully.
    Another thing to check would be the air flow meter because these can be damaged from an engine backfire when running on gas. I am pretty sure the air flow meter is only used when running on petrol.
    There could be a vacuum leak beween the air flow meter and throttle body also.
    I agree about going to another mechanic because it sounds like your mechanic doesn't have a clue.
    Last edited by Tree cutter; 30-01-2009 at 12:57 PM. Reason: Added more information
  17. #17
    Jan 2009
    Hey thanks all for the help. Mechanic looked at the car on friday and long story short but it turns out that i must have had some bad fuel in the tank as its now running perfectly again, mechanic added something to the tank and i filled it up and have been driving on petrol on all weekend and its pretty much perfect. Thanks again
  18. #18
    May 2006
    For the future information of us all, it would be good to know what the 'mechanic' did add to the tank.
  19. #19
    Low_VX_Taxi's Avatar
    Low_VX_Taxi is offline Blanned
    Street sweeper
    Dec 2006
    On the couch
    Quote Originally Posted by pablo View Post
    My moneys on injector cleaner....
  20. #20
    vx executive
    Apr 2008
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by south21 View Post
    my money is on 250 to 500ml of metho
    wat does using metho do? i thought that was just 2 remove moisture?
  1. [QLD] Toyota Hilux Dual Cab 2001
    By Taddy in forum Vehicles For Sale
    Last Post: 09-02-2009, 02:07 PM
  2. DUAL FUEL rough idle on petrol, perfect on gas.
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2008, 03:30 PM
  3. Dual Fuel VS - Missfiring? on Petrol
    By Wojzilla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 12:24 PM
  4. vq statesman dual fuel v8 or petrol v6?
    By Mazzone_Child in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2005, 02:30 PM
  5. Driving me crazy
    By shrimp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2005, 04:10 PM
