Results 1 to 11 of 11
Thread: Converting VT to manual transmission
    VT 2 Acclaim
    Jan 2009
    Default Converting VT to manual transmission
    Hey guys, just bought a VT 2 Acclaim with auto transmission, just wondering roughly how much a conversion to manual trans would cost me, roughly?
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    $3000+ depending if you do the work it will come down a bit
    no longer a hoon by association - the commodore is gone
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Did this with my Dad last year. Cost $1300 for all the second hand parts. Then add up to $1100 for new flywheel/clutch kit (I highly recommend).
    And add maybe another $1000-$1500 for labour if you can't do the work yourself. It's one of those pain in the arse jobs (took two mechanically apt individuals two days), then you may have things to iron out later on.
    Drive around in the auto for a while!
    VT Berlia
    Aug 2007
    Belgrave, Victoria
    I am thinking of getting my vt converted to a manual. I have a friend that has a crashed ss and would give me the gear box and the clutch kit for a cheep price. i also have some friends that are mechanics. my question is, will the vt ss gear box work in a vt Berlia v6, and would there be anything else that i would need from the manual car to put in mine. is it worth me to put a manual in, eg better for the car, more performance. Any help would be grate, thanks
    VT Acclaim 5M
    May 2008
    It's going to be a lot harder to fit a V8 box. The bellhousing will be different, so you will need an adaptor, the flywheel won't bolt up the same, the crossmember will likely be different, and the tailshaft may not fit properly, so you will need to source all these parts and maybe have custom ones made.
    You will also need a manual memcal, clutch pedal & brake pedal, master & slave cylinders, the gear stick, knob etc. And the biggest thing will be the manual wiring loom, which may not fit the v8 box!
    And the V8 box has different ratios so you might need to get a new diff or diff gears to get it to drive nicely.
    Not a project I'd be willing to take on...
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    you boys can just buy my v6 manual. 100,000kays
    feg
    feg is offline
    VT S S/C
    Jul 2006
    Quote Originally Posted by vorn View Post
    or if you don't want to source all the adaptor plates etc, just put the v8 in as well. that would mean more performance.
    VT Berlia
    Aug 2007
    Belgrave, Victoria
    Quote Originally Posted by kart_racer View Post
    WOW!, didnt think it was that big of a job.
    I think i will just wait a bit and get myself a V8 with the manual alredy there.
    wes
    wes is offline
    VT SS 5 spd man.
    Feb 2005
    brisbane
    hi,my son is thinking of buying a 1998 vt commodore,v6 5 speed,but the clutch slips,im wondering if the manual gearboxs in the vt's ever come out with a T5,or just the getrag,,if anyone could let me know that would be good thanks.
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    Just the getrags mate, but u can fit a t5 to them if u like. Ive done it to my vt
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    Vt Wagon
    Aug 2011
    Just finished converting mine. Took about 3 days. Had to replace computer bcm loom pedal box gearbox tailshaft gearbox mount support and master and slave cylinders. It's a pretty big job. The only way is to have every piece out of a car that has same engine as yours.
  1. Looking at converting to manual transmission
    By God-Man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 11:17 PM
  2. converting a vh auto to manual
    By benny999 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-03-2008, 01:55 PM
  3. converting vh slx 4.2 auto to manual
    By gtr161s in forum VB - VC - VH - VK
    Last Post: 02-05-2007, 06:51 PM
  4. converting to a manual
    By Butler_22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 09:16 AM
  5. converting VP auto to manual
    By mattbiggs01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 06:57 PM
