Results 1 to 5 of 5
Thread: VT on gas exploding noise then engine cuts out
    VS executive
    Feb 2008
    Exclamation VT on gas exploding noise then engine cuts out
    hey
    yesterday i was drivin home ( lots of lights stopping and starting)
    when my commodore decided to make a exploding noise and just cut out i'm not sure if it came from the gas tank or if it was backfiring (it happend three times)
    its happend twice before yesterday but my mechanic had said that it was normal for it 2 do this on hot days ...
    a) it wasn't particularily hot yesterday in sydney
    b) is my mechanic correct and am i just overworring
    thanks
    James
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Get the gas system check to be sure.. But more then likely it was just some type of back fire. But check for your own safety at least once every 2 years.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VX 2001 Commodore Exec.
    Jan 2009
    I had a very similar problem when my VX was first converted to gas. As it turned out i needed new spark plugs. I have had the spark plugs changed and it has never happened again. Hope that helps.
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by Jimmyboy91 View Post
    thanks
    James
    No backfiring may be a common fault/problem, but no it isnt normal or should be tolerated. Though for problems some people dont know how to fix, it is often convenient to say "they all do that", or "its normal".
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Some hot days can cause backfire, but only small on startup, due to more chance of vapours, from gas and petrol. Apart from that, should not happen as Commsirac said.
  1. engine just cuts out
    By Pimpin' VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2006, 12:51 AM
  2. engine cuts out
    By al2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2006, 09:21 PM
  3. VR Engine Cuts Out
    By tommo824 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 03:56 PM
  4. vn engine cuts out
    By willi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2005, 04:11 PM
  5. Vn Engine Cuts Out
    By arty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2003, 01:04 AM
