Results 1 to 12 of 12
Thread: VT series II 1999 - engine stalls
    VT Executive S2 1999
    Jan 2009
    Seven Hills, Sydney
    Default VT series II 1999 - engine stalls
    My Holden Commodore VT Series II 1999 model Olympic Edition has started giving me problems. The engine stalls while driving for no apparent reason. There is no trend that I can establish so far. The mechanic kept driving the car for 2 days but could not find the problem. We put the car on the diagnostics computer and found no errors except some errors to do with the ignition key and the lock. Could anyone please let me know if they had a similar problem with their car and what do you think I should check since we have checked a few things and could not isolate the cause.
    Thanks Nicolas321
    VT commodore executive
    Jan 2009
    Same thing happened to me. It was the DFI module/Coil Pack. it is the module which the spark plugs connect to, from the engine. They can get hairline cracks in the circuit board, which makes them perform intermittently. I picked up one from the wreckers for 60 odd bucks and swapped it myself - damn easy. Problems went away. common fault for VT's.
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    ours does it. havnt found an answer yet. it stops. most times it restarts automatically sometimes not. hit the key it runs again. hot and cold. just about ready to shoot the mungrel thing
    VE International Sportswagon II
    Jan 2009
    Mines doing same thing! Did loads of searching online. Most suggeting CAS (crank angle sensor).
    Found out how to get codes (pins 5&6). Came back with 46 & 47
    Before I assume I've worked it out when Holden delership said they had no ideas.... Can someone confirm what these codes mean for VT. I could only find reference for VS
    And how can I confirm it's a faulty CAS.
    P.S. My gf doesn't love it when cuts out on freeway doing 100k, loses powersteering etc. I'm not exactly a fan either but can mucle the car off the road. Seems very unsafe!!!
    Vn Calais/ Vt Sedan/ Vt Wagon
    Nov 2008
    hey
    from the problems ive had with my vt's i would try the CAS, not a very hard job, if not that then i would try the DFI module, it could be the fuel pump as i just found out with my vt wagon, but no code comes up for this with the ecu. the last thing, that i would try first it try using your spare key, your normal one could be failing
    Hope all goes well
    Nov 2008
    Oh by the way BrisbaneVTOwner the Error codes 46 and 47 are
    Code 46 = No Reference Signals while Cranking
    Code 47 = Crank Angle Reference Signal
    Hope This Helps
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Yeah definately the Crank Angle Sensor.......its an extemely common problem on the Ecotec V6... especially once they get a few k's on them.
    coasty's Avatar
    Feb 2008
    kanwal nsw
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by coasty View Post
    anybody know what a cas is worth
    About $90 for the genuine one from Holden... thats what I paid, although it was a couple of years ago.
    coasty's Avatar
    Feb 2008
    kanwal nsw
    thanks for that. stupid car shows no faults, just going to have to start replacing bits and pieces.
    Jan 2009
    Seven Hills, Sydney
    many thanks to all of you there. I am somehow convinced about the CAS unit fault but will wait until I finish my additional research and checking of the various components since I have spent quit a bit of time on checking a lot of things. Yes the car stalls at anytime and it did stall once on the Motorway while I was doing 110 km/h. It did stall as I was taking off on green light. it seems that the problem does not happen when you drive the car for only short distances but rather long distances. Is this consistent with your car faults? thanks nicolas321
    VT COMMODORE
    Dec 2008
    Buy 2 cans of caby cleaner ($12 ea), take off the intake to the TB, insert nozzle and pump away (If its bad, one won't be enough). You will see the black carbon crap pour out of it. Do the IAC and EGR valves as well (take them apart and clean them). Also, do you injectors.
    Then get some new leads and plugs. You will notice a HUGE difference immediately.
  1. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  2. flush radiator VT Series ll 1999
    By badgez in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2010, 08:07 PM
  3. VS Series III 1999 Ute
    By jokerflingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2008, 11:30 AM
  4. Ecu Location Vt Series Ii 1999
    By badly_drawn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2006, 01:30 AM
  5. FS: 1999 VT Commodore Acclaim Series II
    By vt2vygts in forum Parts And Other Items For Sale
    Last Post: 26-10-2005, 08:17 PM
