Results 1 to 11 of 11
Thread: air cond - cuts on in hot weather
    VXII Acclaim
    Aug 2008
    Default air cond - cuts on in hot weather
    Just had my VXII air cond regassed
    Works well except when it's been standing in very hot weather (45+)
    Just blows hot air
    When the weather cools, it work fine
    Any ideas?
    Thanks
    Paul
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Mine does the same but I havent had it regassed yet.
    How much did it cost to regas the VX?
    VXII Acclaim
    Aug 2008
    VT S
    Jan 2009
    bit of a no brainer but is your A/C on or is it just the fan?
    mine use to do that because i didnt know when A/C was on or off coz the light didnt work on it..
    VXII Acclaim
    Aug 2008
    VXII Acclaim
    Aug 2008
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    My home air con was recently cutting out over 40 degrees, had it regassed and now it's perfect. Although it isn't a car A/C it's the same principle. Maybe you have a leak.
    MY RIDE
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Check to see if your electric fan is working when the air con is on. You could have a blown fuse, crook relay or crook fan motor which will let your air con gas overheat so the pressure rises to the point where the pressure switch turns off your compressor so parts of your air con system do not explode.
    VT spac super6
    Nov 2008
    Riverton sa
    get the hose and blast the cr*p outa the condensor.. (radiator looking thing in front of the radiator)
    if the refridgerant isnt cooling down properly it wont cool properly...
    also is the compressor still running when its blowing hot air?
    2000 VX Berlina
    Dec 2008
    my van does that, but substitute 45 degrees with 30 degrees
    it resulted in me driving down the highway with my head out the window because the vans shape results in f*ck all air getting through the cabin with the windows down.
    afaik its probably blowing hot air because the entire air vent system (at least in the van) is made of black plastic so it actually blows hotter air than the stuff in the rest of the cabin.
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Maybe when it was last regassed they put too much in? So on a hotter day the pressure goes up and the pressure switch shuts the compressor off?
    Wouldn't be the first time.
  1. weather
    By shonky12 in forum The Pub
    Last Post: 27-01-2009, 07:02 PM
  2. Power steer cuts out then cuts back in!!!!
    By fnlow1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2008, 01:03 PM
  3. Weather
    By KingDiamond in forum The Pub
    Last Post: 07-09-2006, 06:46 PM
  4. VS v6 a bit under the weather.
    By Jason in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2005, 06:42 PM
  5. Bad weather
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2005, 07:26 PM
